Author Topic: Structural integrity of Stock forks w/ out fender?  (Read 54101 times)
Offline Roach
Re: Structural integrity of Stock forks w/ out fender?
« Reply #250 on: February 24, 2011, 09:14:23 AM »
fast from the past doesnt sell anything for the 550 any year..
that being said i still dont know if the one for the 500 will fit?
1978 CB550K Cafe Racer
« Reply #251 on: February 24, 2011, 09:34:26 AM »
Man for the 400 and 500/550, I'd give that TKat guy a shout. (Prior posts) Custom made and reasonable.
You may have some side fender clearance issues. I'd remove the stock fender fork bracket and hang the fender from the fork brace. Cleaner.
Offline somesuch
« Reply #252 on: February 26, 2011, 12:11:22 AM »
Yea, I talke to Tkat today, and he said he would do it if he can get the 400 and 500 forks measured. Shoot him an email with dimensions.
--Nick
Offline socalenduro
« Reply #253 on: March 02, 2011, 04:10:25 PM »
i just tested my 350f and wish i hadnt...
standing in front of the bike, holding the wheel straight between my knees i turned the handle bars.
the fork twists quite easily qith and without the fork brace (stock with fender drilled out/off) in place
even with a fork brace above the wheel it seems like it needs to be welded or bolted into place on each leg (not just clamped) to over come that kind of force. Wide bars give lots of leverage
« Reply #254 on: March 02, 2011, 04:21:26 PM »
Oh yes, there is heaps of inherent flex in these old front ends, i can't understand anyone arguing otherwise, bracing makes a difference, whether it be a small difference or not, and without it i would have to change the way i ride, for example, braking deep into a corner, thats where i notice it most. I ride fairly sedately now, but by the sounds of things some guys here would still think i ride hard, i will say i ride hard enough to notice the difference between a braced and unbraced front end....My K build has 43mm forks and i will still use a brace....
« Reply #255 on: March 02, 2011, 04:25:16 PM »
RR: Yup.
Offline somesuch
« Reply #256 on: March 02, 2011, 04:25:32 PM »
the surface area of the clamp is very large for the force/direction of force, and there is no problem at all. It is kind of like the triple clamp is clamped on the forks, and not welded to them.  You will be very surprised to repeat the same test with the brace on, and you will be even more impressed by how the bike feels when riding aggressively. Once you bolt it on, you will see how strong the brace really is. It is much better than another brand (it was supposed to be model specific) I had that came with a shim (looked like a slice of beer can) to wrap around the fork leg. I can only assume that the generic brace with different size shims was used to fit many different models.
The Tkat brace is really over engineered, no worries :)
--Nick
Offline socalenduro
« Reply #257 on: March 03, 2011, 06:31:36 AM »
I ride like a little girl, but i still want a front end thats stiffer than a 1990s mountain bike
Offline stueveone
« Reply #258 on: March 05, 2011, 01:23:54 PM »
You don't think you need a fork brace until after you ride a bike where one is installed.
Night & Day.
ALso: RR you shouldn't be breaking at all in turns mate! 'Tis poor form!
« Last Edit: March 05, 2011, 01:27:00 PM by stueveone »
Offline fatmatt650
  • Part Deux
« Reply #259 on: March 05, 2011, 03:55:27 PM »
This whole discussion is just silly. I simply used TWO zip ties per side to hold my Dunstall fiberglass fender on thereby DOUBLING both clamping force and area. I now have a front end that is TWICE as stiff laterally than the factory set  up and independent testing has confirmed that is now 378% more "CafeRacery"tm than before!
Unfortunately, standard zip ties are insufficient for this application. Luckily, I recently acquired a stockpile of these special "CafeRacery"tm zip ties from a Japanese estate sale and am making them available to you for the low, low price of only $17.95 ea. Four are required for installation. Instructions included w/ purchase.
« Reply #260 on: March 05, 2011, 04:57:07 PM »
"ALso: RR you shouldn't be breaking at all in turns mate! 'Tis poor form!"
I would hope he doesn't break in the turns also, nor on the straightaways.
Now braking is another issue...  ;D   ;)
Offline stueveone
« Reply #261 on: March 05, 2011, 05:18:05 PM »
I blame whisky for that grammatical error! But yeah, breaking around a turn is even worse than braking!
« Reply #262 on: March 05, 2011, 09:51:01 PM »
I hope you are kidding mate, i always brake into the start of a corner, always have and always will. Some of you guys must have weird riding styles. Ever ridden on a race track.? if you aren't braking late and turning in whilst doing it you get left behind. Watch the Moto GP and you will see it in every corner... ;)
Offline stueveone
« Reply #263 on: March 06, 2011, 12:13:02 AM »
Notice he gets all of his braking and downshifting done before the corner?
There's also some people that will say easing off the brakes into the start of a corner is proper technique. Like "trail braking".
I haven't heard of anyone advocating hard braking while IN corners. Maybe I'm reading the wrong books?!!!
« Reply #264 on: March 06, 2011, 02:23:52 AM »
I'm talking about entering a corner as you brake and tip in whilst still brushing off speed. You are still leaning and braking as you enter the corner.I didn't say braking in the middle of the corner. I don't know if i am explaining it correctly but if you only rely on engine braking as you tip in you are wasting precious tenths. Watch Moto GP or World superbikes and you will see the back wheel in the air and going out sideways, thats because they are still braking heavily as they set up for the corner but they have already started entry whilst under brakes, then you need a smooth transition between that and a trailing throttle until you ease on the gas to exit the corner . Knowing where to get off the brake is the trick. You can also use the back brake to help stop the rear wheel spin when exiting the corner under power.
Offline Steve_K
« Reply #265 on: March 06, 2011, 05:43:53 AM »
Riding at WSB and Mtg levels is not possible on the the street, but being able to brake leaned over is important.
I read that a Mtg rider will enter the corner hard on the front brakes, flick it to his knee, adjust throttle(for available traction), use the rear brake to controll wheel spin, weight the footpegs(Raine was said to wear out a pair boots in a race), push the bike up with your knee(Diahann said he did that 2 or 4 times a lap), ease off the brakes, use the front brake to give the front tire some traction, and then square off the turn.  The rider is also thinking on how to pass the rider ahead and deal with tires that are going off.  I don't wonder why they are paid big money.
Sorry,I got off topic,  I do brake into the corner, and I try to most of the braking straight up, but that is not always possible.  When I ride the twisters, I tell my friends I do not use brakes, just engine braking.  For me its a fun way to judge corner speed.
Steve
Steve_K
« Reply #266 on: March 06, 2011, 09:54:25 AM »
What are wsb and mtg levels?...guessing its something to do with road racing?
Offline Roach
« Reply #267 on: March 06, 2011, 10:02:46 AM »
wsb= world superbike
mtgp= moto grand prix
Offline Roach
« Reply #268 on: March 06, 2011, 10:06:35 AM »
still havent seen the question i posted up answerd ....
is the 500 fork the same as the 550 fork are the legs the same distance apart if so would a 500 brace work on my 550?
« Reply #269 on: March 06, 2011, 10:14:24 AM »
duh
« Reply #270 on: March 06, 2011, 02:26:59 PM »
Steve
You correct with everything you have said there Steve, I only used Moyo GP as an example to see what i was referring too. Watched a cool TV show  last night that was all about Laguna Seca Race track in Cali, it featured Nicky Hayden , Troy Bayliss, Rossi and others, the braking technique i am referring too was clearly visible with the front fairing mounted camera on Haydens Bike, actually you would be surprised to see how far into the corner they brake..... ;)
Offline stueveone
« Reply #271 on: March 06, 2011, 11:57:21 PM »
Gotcha RR. Did a little more reading and sounds like you're advocating the trail braking technique. I read braking "in" a turn as you waiting to grab a handful of lever at the apex. Either way, from the sound of it you know what the you're doing!
But I totally agree that the fork brace is very apparent while braking into the start of a turn. I'm really starting to think the fork brace is the single most drastically noticeable suspension upgrade that I've done. Though I'm still waiting on my new Ikon rear shocks to come in the mail. . .
« Reply #272 on: March 07, 2011, 12:10:34 AM »
Its good to hear from someone that rides hard enough to feel and understand the difference made by having a tighter front end. Sometimes its easy to take for granted that everyone knows what i am talking about, i find typing a poor way to communicate, rather have a chat over a couple of nice cold beers after a spirited ride.... ;D ;)
