Author Topic: cb550 ressurection hi rpm power loss  (Read 2805 times)
Offline lofijsc
« on: January 16, 2011, 05:37:44 PM »
Hello,
I recently picked up a rotton 78'cb550k out of someones back yard. it was dead for decades. I have some experience with cb's in general so I had a good time getting it ship shape. But I was hoping to get some carb advice from you gurus out there.
It is miraculously running strong with a little popping on the decel but I feel like the power really drops off at hi rpm (6500 or so). I was wondering where I should start.
THANKS
Re: cb550 ressurection hi rpm power loss
« Reply #1 on: January 16, 2011, 06:48:28 PM »
First off, welcome.
Have you given it a proper "3000 mile" tuneup?
Checked compression??
Stock air box and exhaust???
I would start there...
Offline lofijsc
« Reply #2 on: January 16, 2011, 10:21:05 PM »
Thank you, happy to be here.
I have:
-set the points
-adjusted valves
-changed oil
-cleaned carbs
-new plugs
-tested coils and caps
-NOS repacement gas tank/new fuel lines
It has a stock airbox but the exhaust is a modified cb650's 4 to 1.
no compression check and no carb sync.
Offline Kong
« Reply #3 on: January 17, 2011, 05:57:29 AM »
Did you replace the air cleaner?  Its the only thing missing from your list and if there was a mouse nest in it that might restrict airflow at high RPM a good bit.  Another possibility, and kind of a long shot, but possibly the centrifugal advance weights are stuck.  I just put a Dyna ignition system on my aged 550 last week and while doing so found that mine were frozen solid.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #4 on: January 17, 2011, 06:12:39 AM »
Hey lofijsc........welcome ......where are you located
My 78 550 k was cutting out in the higher revs when I was pushing hard.....I replaced the condensers with new ones purchased on E-bay(Cheap Daichi), lubed the advancer and re-set the points.........luck of the draw I don't know but the cutting out stopped,
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline lofijsc
« Reply #5 on: January 17, 2011, 09:27:28 AM »
@Kong- The airfilter is free of debris, but I did cheap out and not buy a new one. That could be the culprit. Can the filters be cleaned and re-used? I had a cb750 with a frozen advancer once. It took me hundreds of wasted dollars to figure that out.
@tjjkc- I will put the condensers on my list of suspects. As of right now the bike doesn't cut out. It just feels like the bike's power band drops off way to early. I read in the specs that peak HP was at 8000ish. Not on my bike. After 6000rpm it pulls like pig, so I'm hoping it's a tuning thing and not a geriatric motor. BTW, Thank You :) I am located in OC, CA
Offline lone*X
« Reply #6 on: January 17, 2011, 10:01:54 AM »
Since you indicate it runs OK in the low and mid range it sound like most tune up items are acceptable.  Look at the carbs again.  Are you sure you got the main jets all clear?  Visible light thru the jets?  Sounds like clogged mains (high speed jets) to me.  You may want to strip the carbs again and make sure all passages are clean and clear.  Then get them properly synced.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #7 on: January 17, 2011, 10:49:56 AM »
The paper filters can be back blown at 3 months and replaced at 6 months.  They can't ever be completely cleaned per design, plus the paper fibers collapse making the air passages smaller through them.  In short, they get too restrictive, deepen the carb throat pressure and draw too much fuel from the carb jets.  They effect is worse at higher air velocities.
If your spark plugs are coated with black soot, it's running too rich.
BTW, the owners manual outlines the filter replacement schedule clearly.
