Author Topic: 550 OverBore (Phoenix redux)  (Read 6718 times)
« on: January 17, 2011, 06:20:56 PM »
was gonna add this to my last build thread   ( http://forums.sohc4.net/index.php?topic=42532.0 ) but i  thought it better to just start a new thread BECAUSE there are a bunch of 550 big bore threads or Gentleman's Express builds ... but none of them are finished!!!! (the threads anyway)
  so i thought somebody way down the line doin search will get some closure and see the finished product (i hope  ;D ;D )
 so this has been my plan for quite some time, just got thrown on the backburner while gathering parts
so here is the plan :
retro fit 80's 550 Nighthawk oil cooler
CB750 pistons ..machined flat top (not the gentlemans express profile)
CB650 primary chain tensioner and oil pan
(i wanna try and mod the tensioner so that i don't need the 650 oil pan, cuz i like my exhaust the way it is)
  and you could refer the link above and see the head and the rest of the top end
so my plan was to use all my spares to build this bottom end, i have enough to build 2.... but upon inspecting this one , and seeing how bad the primary chain was , i thought i should check the chain that's actually in the bike .. and that was not to good either
  Sooooooooo... this now becomes a mandatory upgrade , and since i'm gonna be in the cases any damn way .. i'm gonna play ;D
on with the show
WOW !!!!!
WOW!!!
WHOA!!!   probly gonna bring this to work and put some weld on that oil passage, just for piece of mind
      Now for the oil cooler..
normally i don't start threads till there is more to share ... but it seems i have lost a bunch of pictures taken during some of the process so i thought i'd start the thread before i got too '"dis-com-bob-u-late-ed"
    so, go ahead and open a new tab and search Ebay for an 80's 550 Nighthawk oil cooler ..... go ahead i'll wait ..
ok .. so now you know what it used to look like .... i had to cut the center out, remove some of the meat at the top fins(where the oil filter joins) and remove alot of the cooling fins on the motor block so it would fit together
before
after
thats the start , will be getting my pistons back from the lathe guy at work in a week "or so"
should have my primary chain the next few days as well
« Last Edit: January 22, 2011, 02:13:44 PM by Spikeybike »
Re: 550 BIG BORE (Phoenix redux)
« Reply #1 on: January 17, 2011, 06:28:00 PM »
and yes i plasti-gauged the crank and it checked out A-ok  (lost/deleted those pics too :( )
« Reply #2 on: January 22, 2011, 11:38:10 AM »
so .... after doing some math , and figuring the money out , customizing the pistons , getting rings , Cometic gasket , plus the 3mm overbore, are just too damn expensive  :'( :'(
so  instead i'm gonna do a 1.00mm overbore bringing it to somewhere around 555  , i got a good deal from a friend of a friend of a friend  running an ebay store, (a PITA but worth it once i saved 50%)
 so the pistons below with the correct oil sweeper rings , are on their way to my house
i got the wrong oil seal kit so i'm waiting on a few oil seals then i can bolt the lower cases back together
 i do love seein that ... feels good to finally get this ball rollin after waiting for so so long   ;D ;D
Offline four_shot
    • For the Cherokee lover in you.
Re: 550 OverBore (Phoenix redux)
« Reply #3 on: January 23, 2011, 09:44:33 PM »
sweet. That primary IS scary.  glad you found it when you did. post up a pic of the 650 pan/tensioner set up so I know what your talking about.
in memory of Dave "Gonzo" Steele
Offline 50BMG
« Reply #4 on: January 25, 2011, 08:40:07 AM »
four_shot this might help you understand
http://forums.sohc4.net/index.php?topic=80690.0
« Reply #5 on: January 30, 2011, 06:40:19 AM »
so i'm trying to think of a way to mod this tensioner so that i don't need the 650 oil pan ... the only ideas i can come up with is to cut the spring tab on the bottom off , re-weld it higher up , and use a shorter spring ... i can't find a reason why that would be a bad idea, as long as i use a strong enough spring .   any opinions?
« Last Edit: January 30, 2011, 07:06:57 AM by Spikeybike »
Offline q2418130103p
« Reply #6 on: January 30, 2011, 04:38:22 PM »
I dont know, but I would assume you would have to do some back of the envelope calculations to make sure you are applying a similar force against the chain after you change the spring constant and leverage.
What does it take to mount the tensioner int he first place?  Is the 650 pan a direct replacement?  I'd like to do this on my 550, the cases are currently stripped.
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline four_shot
« Reply #7 on: January 31, 2011, 05:55:50 PM »
Read this thread. It should answers your questions.
« Reply #8 on: February 15, 2011, 11:44:23 AM »
driving to the machine shop to drop off my pistons and cylinders today , for bore and hone the cheapest i could find without having to drive 60 miles or more was 80 bucks a hole  .. the upside is it's a honda dealership so they should know what they're doing  ;) ;D
  thank uncle sam ...that greedy bastard
« Reply #9 on: February 16, 2011, 04:16:40 AM »
ouch, thats a rough price for a bore and hone.  For that price they better coat everything in gold while they are at it.
« Reply #10 on: February 16, 2011, 01:12:55 PM »
just used an online displacement calculator...  when all is said and done , i should be at 563cc
Offline Zaipai
    • My Home page
« Reply #11 on: February 21, 2011, 08:07:52 PM »
Dude, don't know how I missed this thread. What do you suppose caused the primary to do that? The beefier cam you have on that thing? Makes me wonder if I should be checking mine. What is this going to mean for actual power if you go from say stock to 563cc's? Big difference? Bet it sounds better! Do you have to rejet? Bet you do... GL I will be tacking your progress...
.: Scott :.
Its my Avatar..
75 CB550F  |
« Reply #12 on: February 23, 2011, 12:36:15 AM »
ok i finally got the oil filter bolt in the mail today , so i can chop them up and make a longer one
wrapped some tape on it so i knew where to cut , slapped in the vise
once i had the piece i need ,about 20mm .. i ground maybe 2mm off the new bolt , to make sure the weld wouldn't contact the motor case
i wrapped the cap and o-ring with masking tape and spray the mess with anti-spatter, went a little crazy with the anti-spatter actually
i didn't want any slag in the threads or inside the bolt
i only stitch welded it and as you can see in the pic, it shifted juuuuuust a lil bit , so i didn't weld it anymore
and test fit it to see if i needed to change anything
fit perfect  ;D thats done
now i'm just waitin on the jugs :P
« Last Edit: February 23, 2011, 12:38:03 AM by Spikeybike »
« Reply #13 on: February 23, 2011, 12:40:44 AM »
i hate how the halogen lights make the HotRod Red look orange in pics   ::)
Offline Zaipai
    • My Home page
« Reply #14 on: February 23, 2011, 05:30:23 AM »
That's ok when you are done, take it out side and get some good pictures. For now, its cool that the bolt worked even shifting the tiniest amount. Keep going man, spring will be here before you know it! ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline moham
  • .fnord.
« Reply #15 on: February 28, 2011, 08:33:05 AM »
well, at least one of us finished a 550 over bore project and thread :P
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
« Reply #16 on: February 28, 2011, 10:06:36 AM »
That is very true my friend ...but there are like 10 that aren't finished ....and in my defense ,I hadn't seen your thread yet when I wrote that
Offline moham
  • .fnord.
« Reply #17 on: February 28, 2011, 11:54:23 AM »
haha man, just giving you crap...and my thread is a year old so that's like 50 innernet years.
gl with your project! i'll have to get mine out of the shop soon and see if she still goes
78 750K-The Ocho
« Reply #18 on: March 07, 2011, 01:58:31 PM »
i just got off the phone with the machine shop ... it seems i was given 3 pistons at 1mm over  and 1 piston at 0.5mm over ... sooooooo #$%*in mad right now ..
so i gotta order another piston THEN try and return this one , all the part #'s are the same so it was mis-packaged..   lookin like i'm out $80 and probly won't have this together by the end of May when the world tour hits the midwest leg  >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:( >:(
« Last Edit: March 07, 2011, 04:49:07 PM by Spikeybike »
« Reply #19 on: March 07, 2011, 01:59:05 PM »
Offline Zaipai
    • My Home page
« Reply #20 on: March 07, 2011, 04:42:40 PM »
I don't know May is still a ways off.. I believe you can do it. I am just getting parts for mine so not sure I will have it finished so you have to have yours done so some one can take the mantle! ;)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline four_shot
« Reply #21 on: March 08, 2011, 08:56:45 PM »
Just had to throw the extra one in there huh
« Reply #22 on: March 09, 2011, 09:05:11 AM »
Dude...that #$%*s so #$%*in lame , the part that really burns me is that now doing the 592cc woulda cost just as much as this 565cc ...and now I gotta just sit and stare at it for another few weeks ... Mad face
« Reply #23 on: March 09, 2011, 10:11:37 AM »
So just for #$%*s and giggles , I just sat down with a calculator and figured out how much money I've put into just my motor ...
Over the past 10yrs, the grand total comes to a whopping $2,263  :o ;D
Offline Zaipai
    • My Home page
« Reply #24 on: March 09, 2011, 07:54:53 PM »
Yea, but as far as hobbies go its really not that bad at all! ;) Worth every penny if you ask me!
.: Scott :.
Its my Avatar..
75 CB550F  |
