Author Topic: Indicator problem??  (Read 1373 times)
Jim Shea
Indicator problem??
« on: March 26, 2006, 01:47:10 AM »
Hi chaps how are you all??
I took off my indicator flasher unit a while ago as it was only working intermittently!
I have a green a grey and a black wire going to the flasher unit, the flasher unit is marked with an X, P and L...can you tell me which colour wire goes to which?? I seem to remember there is a quick check to see if the unit is working OK, by connecting a wire somewhere!!????
If it is not the flasher unit that is dead, is there another obvious reason why none of the indicators are working?? I could not seem to find a fuse specific to these?
Jim.
« Last Edit: March 26, 2006, 04:05:14 AM by Jim Shea »
Online bryanj
Re: Indicator problem??
« Reply #1 on: March 26, 2006, 06:01:20 AM »
If you connect the grey to the black the flashers should come on when the switch is operated --but not flash of course--- I have no idea what the letters x p and i mean tho
Jim Shea
« Reply #2 on: March 26, 2006, 08:15:55 AM »
Bryan,
Thanks.. Do I assume that the F1 originally did not have a 3 wire flasher unit??
Jim.
Offline mrblasty
  • Expertly
« Reply #3 on: March 26, 2006, 09:22:47 AM »
My k3 has only two blinker wires.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Jim Shea
« Reply #4 on: March 26, 2006, 10:26:14 AM »
I can't believe Honda changed it just for the  F1... did they????
supersport_CB400F
« Reply #5 on: March 26, 2006, 10:44:33 AM »
I have grey green and black wires on my 400F
Green center- Black left- Grey right
« Last Edit: March 26, 2006, 11:09:36 AM by _biffta_ »
