Author Topic: Can't get these CB750 cases apart  (Read 1201 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: January 19, 2011, 08:26:10 AM »
Going dumpster diving in this old motor for parts once I get it apart but I'm having trouble doing that. I've removed all the bolts I'm sure. Can't get it to crack open though. Is there a pry point somewhere?
Offline SOHC Digger
  • I'm not an
Re: Can't get these CB750 cases apart
« Reply #1 on: January 19, 2011, 08:40:06 AM »
There's not really a pry point, just several strategic places to strike with a plastic or rubber faced hammer.  The sealing bond and the dowels do such a good job holding the cases together that you just have to go round and round tapping on the edges where the mating surfaces don't fit flush.  Inside the clutch housing is a good area to start.
Offline Shoeboxjoe
  • Large Breasts
« Reply #2 on: January 19, 2011, 08:43:20 AM »
I think i used a paint scraper to start opening the case around the points. Crack the front seam and open the cases like a clam shell being careful not to pry too much on the mating surfaces for obvious reasons.
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #3 on: January 20, 2011, 12:05:42 AM »
Myles,
I tapped the rear with my rubber mallet. There should be a place or 2 that overlap.
« Reply #4 on: January 20, 2011, 09:44:47 AM »
I also think that there is an area that has kind of a flat tab section at the rear of the crankcase that may be considered a gentle "pry" area.
« Reply #5 on: January 20, 2011, 10:38:53 AM »
 Check starter cavity. may be a missed case screw in there..
 No reason ever to pry anything apart at the seam or join.. cept maybe to prove you are a dumbass..
 There is aways another safer way, the only time , it is real tricky is seperating head from cylinder if you are trying to keep barrels on and base gasket intact..
Offline Elan
    • Vital Motor Parts
« Reply #6 on: January 20, 2011, 10:53:58 AM »
I had to prop up half with a 2x4, and slowly pulled the other half toward the table.. Just enough to get it moving.
76 750k
« Reply #7 on: January 20, 2011, 11:15:29 AM »
Too much work..
 To get it started, put 2 bars or bolts in rear motor mounts, now between them, use a 2x4 and a wedge, or a pce of reddi-rod, with a nut on either end, then turn the nuts to spead ot (ie, jack it gently apart. Try clutch side, the long mount on chain side, could break with too much force..
 When one end goes, the rest is easier..
Offline markb
  • When I finish my current project I might be a
« Reply #8 on: January 20, 2011, 12:27:45 PM »
Too much work..
I like that idea.  :)
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
