Author Topic: CB550 Cam Cover Installation Question  (Read 3632 times)
Offline allhonda
« on: January 19, 2011, 09:14:59 AM »
OK, before I screw something up I need some help. I have replaced the 6 sealing rubbers below the cam cover and installed a new cam cover o ring. I am now trying to line up the cam cover to secure with the bolts. Is there a trick to this as it seems to not line up correctly? I know in the manual they caution about watching how the rocker arm tappet adjusters contact the valve ends and to reach thru the openings and pull up on the rockers arms to align properly. Also what about lining up the gear for the tachometer? Could that be an issue?  Does the cam need to be in a certain position?  I am afraid to just start tightening bolts, I don't want to bend a valve or have the tachometer gear not line up. (I will be compressing a few valves as I begin to tighten the bolts, right?) What is the trick to reinstalling this cover?  Any feedback from someone who has done this succesfully would be appreciated. Thanks in advance! I know some of you guys are mammoth knowledge about these bikes and is why I love this forum!
valkyrie, ct90, ct70, atc185s, cb550
Offline allhonda
Re: CB550 Cam Cover Installation Question
« Reply #1 on: January 19, 2011, 09:17:18 AM »
This is a 1974.
Offline Roach
« Reply #2 on: January 19, 2011, 02:19:25 PM »
ok something i can answer
remove your tach gear take it right out install it after the cover is down.
remove the tapit covers all 8 of them.
go to your kitchen or where ever you keep your elastic bands get 4 of them or more if you shoot one across the room the first couple times.
then put an elastic from one exhaust tapet "probably will have to put it under the tapet" to your intake tapet. up and over the top not inside do all 4. then place the cover on bolt it down hold the elastic so it doesn't shoot inside the motor cut them and remove. she your tapet clearance with your fealer guages and then put in your tach gear.
1978 CB550K Cafe Racer
Offline allhonda
« Reply #3 on: January 20, 2011, 04:16:07 AM »
Thanks Roach. I wasn't thinking clear yesterday, that all makes sense.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: January 20, 2011, 11:31:35 AM »
A picture is worth a million words:
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Raef
« Reply #5 on: January 20, 2011, 11:41:40 AM »
I have done this more than once and have never used or thought of that little trick.
pretty slick
Mark
Offline allhonda
« Reply #6 on: January 20, 2011, 03:29:41 PM »
That rubber band trick was awesome idea! Worked great! I am back together and running! Just started another post about my oil light coming on a times.
Offline Kong
« Reply #7 on: January 21, 2011, 06:52:48 AM »
That photograph, all by itself, deserves a prized position in one of the Tips and Tricks Forum categories.  Outstanding!
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: January 21, 2011, 10:32:48 AM »
Kong, I think that's where I found it.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline q2418130103p
« Reply #9 on: January 21, 2011, 03:45:04 PM »
The rubber band thing is awesome.
I just find the tappet that is stuck, and gently lift it, then move to the next stuck one until the cover is on.
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
