Author Topic: 1980 Suzuki GS250t Question  (Read 5707 times)
Offline youngndumb
« on: January 19, 2011, 04:18:55 PM »
Hey guys, I have a 1980 Suzuki GS 250t that I've been trying to nurse back to life for the past few months, and have encountered a problem that I've probably considered too long, and am likely over-thinking.  After getting the carbs all cleaned up (many...many times) and the rust removed from the tank (reason for numerous carb cleanings), I was able to get it to fire, idle, and after a float height adjustment (a little rich at 22mm), rev beautifully in neutral.  However, once in gear, it produces very little torque on take off, will nearly stall, and eventually pick up around 4-5k, and run fine up to the top end of 3rd, where it peaks around 8k, and will not pull through 4th at all. The stock air filter is lost somewhere in the graveyard of abandoned motorcycle parts, and the box is currently packed with filter material, I don't know if this is allowing air to move too freely, and causing my problem, or if its an entirely separate issue. If anyone has any idea's, thoughts, or "Hey, moron, do this's" I'd greatly appreciate it.
Offline Dawdlin Dog
Re: 1980 Suzuki GS250t Question
« Reply #1 on: January 19, 2011, 11:16:41 PM »
The GS is pretty finicky about having the right fuel/air mixture, sorting out a proper air filter will probably do a lot to help. Have you checked Timing, valve clearance, points etc?
There is also a dedicated GS forum, http://www.thegsresources.com/_forum/index.php which might be worth checking out.
Good luck with it  :)
My bike can be repaired.
My insanity is a little more permanent.
Offline youngndumb
« Reply #2 on: January 20, 2011, 05:55:22 PM »
Thanks, I just tried restricting the air flow a lot more (I had forgotten how little I had actually packed into the airbox initially) and got much closer to how it should be running. Now its just some trial and error to find that sweet spot, and she'll hopefully be back on the road for the first time since 1983. I'm starting to get the faintest waft of victory.  ;D
