Author Topic: rotor resurfacing safety question - CB750  (Read 3709 times)
nomad
« on: January 21, 2011, 12:04:03 PM »
I've dug up threads here from people discussing them having their rotors resurfaced.  So I called the local Honda dealership to see if they'd do it.  In short, they said no.  I'm guessing for safety/ legal reasons.  Not being "up" on this, I just took them at their word and said thanks.
So, what if any issues are there associated with getting the front rotor of a 750 resurfaced (even a small amount)?  I'm about to get it drilled by a fellow forum member and am thinking of having this done first.  I'm sure it really isn't necessary in my case seeing as how I have only very minor pitting and grooving, but I thought it might be nice to get it back to that "new" look since I'm going trhough the effort to make the rest of it nice and "sparkly."  ;D
What are y'all's thoughts and who does this type of work (and is good at it)?
Offline lordmoonpie
    • Moonpie
Re: rotor resurfacing safety question - CB750
« Reply #1 on: January 21, 2011, 12:09:50 PM »
I presume you mean dressing the existing surface rather than building it up with something? Issue of dressing the surface will purely be to make sure it's done flat and not too much taken off to take the rotor below serviceable limits. I wouldn't think there's any merit in adding material and dressing back to get a decent finish, that surely would give you issues of separation, warping and goodness knows what else.
Take the rotor off altogether and get a good machine shop to cut you a slice of cast iron, drill and finish that and add it to the internal carrier - you'll have instantly better stopping power. Or, send your disc to CAT Engineering in the UK and Len will do it all for you  ;)
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #2 on: January 21, 2011, 01:15:01 PM »
a few over here offering this service....
http://forums.sohc4.net/index.php?board=50.0
it should be done AFTER any cross drilling/chamferring to get rid of burrs.
had mine done for my 350F.  speedracer741 did it, but dont know if he's around much anymore.
drilled, chamferred and resurfaced. best $80 (incl. shipping) ive spent on my bike.
« Last Edit: January 21, 2011, 01:42:46 PM by flybox1 »
Offline Kong
« Reply #3 on: January 21, 2011, 01:54:30 PM »
I took two of them (550 rotors) to a local mechanic's shop a couple of weeks ago, he tossed them in the brake lath (Snap On) and turned them both, both sides, no problem.  Measured thickness after turning was still far in excess of the 6mm (I think it was) minimum thickness.  So I don't know why your dealership couldn't, or wouldn't do it, but mine are like new now.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #4 on: January 21, 2011, 03:02:10 PM »
Frankly, I can't imagine a dealership having the tools to do it. Its a relatively low volume, generally unnecessary request, IMO.
Though for those of us who want it (I had mine done at a shop in Chicago) its a neat thing, necessary doesn't enter in.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: January 21, 2011, 03:15:25 PM »
Nah, the usual attitude at dealerships is "Why are you messing around with that old bike?  Buy a new one from us!"
In short, they don't consider such work to be worth their time on bikes that are no longer in warranty, and on the newer bikes it's faster (and therefore cheaper to them) to just throw a new rotor on.
mystic_1
- John Augustus Shedd
« Reply #6 on: January 21, 2011, 08:25:17 PM »
Dealer probably doesn't have a lathe, they would rather sell you a new rotor.
We always called it "getting rotors turned".
Offline george
  • Back To My Roots !
  • K8 The Project
« Reply #7 on: January 21, 2011, 09:09:48 PM »
That's something I remember from hangin out at the 66 Station as a youngster, after those rotors had been machined (turned) they look new! After working in Auto parts recently, I discovered our rotors can be cleaned up if the machinist will treat them like a flywheel. They just have to cut one side at a time. A 6mm rotor is too narrow to do both sides at once, Accurately, or so I have been told.
Found this bike in completely stock condition in Feb. 08. Paid over twice what my new one cost 30 years ago. Am trying to re-create the look of the late 70's Drag Bike styling.More later. 4-2-10 It ain't stock any more and I have no idea what I am trying to create !
« Reply #8 on: January 21, 2011, 09:30:49 PM »
 About 4 out of 5 rotors will clean up easily by blocksandinng them in a lathe..
