'73 CB350F. stock electical harness/lights except for a mini 15a mini blade fuse/holder to replace the glass fuse holder.
2 weeks ago, i started her up and ran down the block. fuse blew. first time ever since i've owned this bike(2 years)
pushed her home and let her sit until last weekend. It was raining, so i put in a new fuse, let her run under a fan for 15 min or so. no probs. Yesterday, took out regulator, cleaned all terminals. checked point gap and the armature gaps inside. all were within spec from my shop mannual. cleaned battery leads, ground under seat. idled in the garage, and no probs with fuse. warmed up fine for a ride today, and as soon as i turned on low beams and started pushing out of the garage, fuse blew.
turned all off, new fuse, check ground under seat again....insert key, turned to ON, and fuse immediately blew(no Headlight),
battery is at 12.48v.
i've got a short somewhere. i have a voltmeter that i'm learning to use. I have a good wiring diagram.
Please help point me in the right direction. where should i look?
thanks guys!
