Author Topic: How much front wheel spin normal?  (Read 2035 times)
Offline stueveone
« on: January 23, 2011, 11:37:39 PM »
With brakes adjusted, how many times should the front wheel spin freely before stopping? It's a little subjective a test I realize, but I haven't yet heard a consensus amount of normal wheel free play with the brakes installed and adjusted and with there being a natural floating or kissing of the pad being present?
Thanks!
Offline RippinSVT
Re: How much front wheel spin normal?
« Reply #1 on: January 23, 2011, 11:58:42 PM »
32.67485673, I rounded up.
Offline Roach
« Reply #2 on: January 24, 2011, 12:02:41 AM »
depends how hard i spin it.
1978 CB550K Cafe Racer
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #3 on: January 24, 2011, 04:26:46 AM »
a few.
try a 10 minute ride, disc should be warm not hot.
searching for a dr350se
Offline stueveone
« Reply #4 on: January 24, 2011, 07:53:42 AM »
Not gonna lie, 2 out of 3 of those answers were real clunkers! I guess you gotta pad your number if you want to get to be an "old timer" huh?!!
Just saying, I've seen the question asked before, with the only answers being vague "it should spin..." Figured we could establish an average or something.
Offline Bodi
« Reply #5 on: January 24, 2011, 07:59:03 AM »
Right after brake application there's a fair bit of friction. Go for a ride around the block without using the front brake and put it on the centre stand - but don't touch that brake lever. The wheel will spin much more freely. The brake caliper piston retracts a bit when the lever is released but the pads touching the disc will push themselves apart more in a few minutes riding. With the lever relaxed the brake fluid will flow back to the reservoir freely if the piston is pressed back.
« Reply #6 on: January 24, 2011, 08:08:11 AM »
....your front rotor should not be hot (indicating a dragging pad)...
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: January 24, 2011, 08:45:22 AM »
The condition of the wheel bearings, speedometer drive, and even wheel balance have a big effect on free spin of the front wheel, too.  With all these variables, including the biggest one (how much force is used to spin the wheel), there is no "correct" number of spins.  As long as all the wheel components are verified by yourself to be in good condition, and the rotor doesn't heat up when the front brake isn't used, you're in good shape.
Offline stueveone
« Reply #8 on: January 24, 2011, 12:41:09 PM »
Grateful for the feedback guys. I've worked on many other disc brakes, just trying to get some idea as to what "normal" is on these wacky ol cb set ups.
