Author Topic: Rim and wheel question  (Read 1105 times)
Offline wicat
« on: January 24, 2011, 04:44:34 PM »
I have a 73 cb750 and i want to put some comstar or find a nicer set of spoked rims to use my question is do i need to find a set of 73 rims or can i use a set off of any honda? Also if i find spoked rims like for a cb125 can i use them or are they not strong enough for the 750?
Re: Rim and wheel question
« Reply #1 on: January 24, 2011, 10:55:28 PM »
Comstars wont fit unless you have the forks, discs,calipers etc 125 has a puny drum brake---have you realy got a death wish?
Offline tango911
« Reply #2 on: January 25, 2011, 05:07:59 AM »
u should just re-spoke yours and clean up the rims and hub.
You can get spokes for $29 per wheel.
http://www.cb750supply.com/products/2/chassis-brakes/61/wheel-spokes
here they are on mine, all i did was replace the bearings and brush and sand a little on the hubs and just cleaned up the rims.
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline MattFreeman
  • What Have I Done?
« Reply #3 on: January 25, 2011, 05:44:03 AM »
I've got a pretty nice front wheel for a 750 that I'd let go for a fair price. Whatever that is.
It needs polished up but has not much rust.
Offline wicat
« Reply #4 on: January 25, 2011, 02:36:53 PM »
well if i clean up my hubs and get them relaced my next question would be can i get the new outter rim or the best way to clean it up would be?
Offline Dyrden
« Reply #5 on: January 25, 2011, 02:58:41 PM »
Quick question(even after reading lots of posts)  My 77 750 has a 17 inch rear and I want to re-lace to an 18 inch rear.  I like the symmetry of similar sized front and rear wheel tire and rim combos.  Besides the buchman(sp?) spokes and rims is there another less expensive option for rear spokes and rim?  The rims are getting powder coated.  Thanks.  Sorry for the half hijack.
Offline Red67lemans326
« Reply #6 on: January 25, 2011, 04:51:29 PM »
+1  on the Buchanan spokes being pricey. I would like to know where STAINLESS (CB750 supply are cadmium coated steel, aka won't last forever) spokes can be found for less. And to not hijack your thread....You should re-spoke your wheels, different sized wheels on a bike means it will handle differently (not always better)...and most of the time...the factory wheels are a certain size...for a reason.
Offline Dyrden
« Reply #7 on: January 25, 2011, 05:38:19 PM »
The O.D of the 17 inch wheel plus tire should be pretty similar to a lower profile/width 18 inch wheel and tire combo so Im not too worried about ill effects in relation to handling.  Still need to find rim and spokes though!
« Reply #8 on: January 25, 2011, 09:01:10 PM »
CB125 rims on a 750? You're kidding right?!?
