Author Topic: For those who have redone a seat  (Read 1608 times)
Offline fmctm1sw
« on: January 25, 2011, 06:06:32 AM »
What is the height of the padding or foam you used?  I guess there is some room for adjustment but what's "stock?"  5" or so?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline tango911
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
Offline fmctm1sw
Re: For those who have redone a seat
« Reply #2 on: January 25, 2011, 08:39:21 AM »
It's a 550 and I was going to use carpet padding or a exercise mat as described in some other posts.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Popwood
« Reply #3 on: January 25, 2011, 10:22:56 AM »
Foams have different densities. Thickness then is relative to density, less dense softer foam would need more thickness to approximate the compression a more dense, thinner foam would provide. I'd think carpet pad would fall apart pretty quickly. You can find foam at uphostery supply places. Or call an upholserer and ask where to get it. I ordered a single chuck then "sculpted" it to fit. I wish I had chosen a bit more dense foam.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline fmctm1sw
« Reply #4 on: January 25, 2011, 02:00:55 PM »
Does your padding follow the profile of the seat?  It looks like the back of the seat would be way higher than the front as opposed to a rather level look on my other bikes.  Am I supposed top put more layers toward the front?
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #5 on: January 25, 2011, 08:47:47 PM »
Call Grant's for foam:
Grant's Foam & Fabric
3320 North w Street, Pensacola, FL 32505-3953
(850) 439-6544
Offline stueveone
« Reply #6 on: January 25, 2011, 10:27:55 PM »
Not sure how different a 550 seat pan is to a 750, but I cut a few inches off the original foam with an electric turkey cutting knife, then just re=made the seat cover accordingly. Mine is fairly level, with it only swooping up a half of an inch or so in the back due to the way the seat pan is made.
