Author Topic: 1976 cb750 ss gear ratio? insanely low  (Read 8015 times)
Offline gty2k2000
« on: January 25, 2011, 10:55:10 AM »
i just purchased a cb750F1 1976, and after riding for a while with my buddy i relized that the gearing in this bike is insane. in 5th gear going about 45-50mph my bike is turning @5000-6000 RPM im not sure my speedo is inop. IS THIS NORMAL. and can i change it so that runs on the interstate arent so extream
Offline gty2k2000
Re: 1976 cb750 ss gear ratio? insanely low
« Reply #2 on: January 25, 2011, 11:43:30 AM »
so is this normal for my bike is it ok to run on the interstate at such high rpms
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #3 on: January 25, 2011, 11:50:56 AM »
That s not considered high rpm on these engines. They like to be reved  ;D
In the UK anything over 40 years old only needs insurance and Fuel.
« Reply #4 on: January 25, 2011, 12:11:15 PM »
count both sprocket teeth and see if its been changed from standard.
« Reply #5 on: January 25, 2011, 01:02:23 PM »
5th gear, 5000rpm, ~70mph with stock size tire, 17-48 sprockets
Offline Bodi
« Reply #6 on: January 25, 2011, 05:00:06 PM »
Check the chain sprockets. I don't think you can get sprockets to make that much of a difference though. I think your tach is wrong.
Why is the speedo inop? If someone smashed the front end and replaced the tach with one for a different bike model the ratio may be wrong and the reading bogus. Honda bikes under 500cc have a different tach ratio than over 500cc. Buggered if I can remember what they are.
« Reply #7 on: January 25, 2011, 05:03:26 PM »
Sprockets will definitely make that difference, like others have said, check your sprocket sizes and get back to us...
« Reply #8 on: January 25, 2011, 11:21:48 PM »
i tried a 550 37 rear sprocket on my 500 that should be a 34 tooth,it went well but was like i lost fifth gear,they make a difference alright.
Offline Grabcon
« Reply #9 on: January 26, 2011, 08:31:03 PM »
Follow the link. It is a gearing web site. You will follow the instructions and list your bike. It will show MPH per gear with stock or non-stock gearing. It is pretty simple.
http://www.gearingcommander.com/
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10 on: January 27, 2011, 06:42:37 AM »
If the sprockets teeth count are close to stock then the clutch may be slipping. How many miles?
My 78' CB750 both F and K will cruise at 70mph in 5th gear at 5000rpm with 15/41 sprockets.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Bodi
« Reply #11 on: January 27, 2011, 08:48:23 AM »
"Check the chain sprockets. I don't think you can get sprockets to make that much of a difference"
vs
"Sprockets will definitely make that difference":
According to the posts, he has the RPM at 50mph that should mean 70mph.
That's 1.4x the stock drive ratio. With a 15 tooth engine sprocket (smallest I could find) you need a 60 tooth rear sprocket, not available except by custom order, and it would be obviously oversize.
Offline gty2k2000
« Reply #12 on: January 27, 2011, 09:42:52 AM »
i think the tach is way off and having a 4 to 1 kreager header is intimidating to the ear so the off tachseeems normal
« Reply #13 on: January 27, 2011, 10:08:38 AM »
You could assume that the tach is off. If you are wrong then that would likely mean that the clutch is slipping.
TAMTF...
Wilbur
Projects:
bollingball
« Reply #14 on: January 27, 2011, 10:46:05 AM »
Check the clutch with the old brick wall method in 5th gear.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #15 on: January 27, 2011, 11:24:19 AM »
HOW MANY TEETH ON YOUR SPROCKETS?
No.
« Reply #16 on: January 28, 2011, 03:04:00 AM »
if the clutch was slipping that much i think youd feel it all over,like it would "flare"under accelleration,most of these old tachs speak with forked tonque anyhow,were all still waiting on the tooth count.
