Author Topic: '76 750F rear caliper - couldn't extract the broken bleeder. What now?  (Read 7794 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
Just bought some new brake lines from @pampadori. The old ones are literally falling apart. Went to bleed out the rear caliper and couldn't find the bleeder valve. I guess this was it? Anything I can do here, or do I need to replace it?
« Last Edit: February 02, 2011, 07:46:56 AM by Tugboat »
Offline guitarkev66
Re: Hmmm.... Rear caliper with no bleeder valve ('76 750F)
« Reply #1 on: January 25, 2011, 06:56:12 PM »
I would try to drill it carefully and try and easyout bit after soaking it with lots of penetraiting oil spray
1970 K0 CB750 JDM Blue
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Offline ofreen
« Reply #2 on: January 25, 2011, 07:06:09 PM »
Your bleeder screw is broken off.  If you can get the remnant out, you can replace it.  Heat, penetrating oil, and patience are your best bet.  I like PB Blaster.
Greg
'75 CB750F
« Reply #3 on: January 25, 2011, 07:10:39 PM »
Good luck, that will be tough. Try the above suggestions but I would start looking for a replacement.
« Reply #4 on: January 25, 2011, 08:49:08 PM »
I now know of 2 of you in a similar predicament. You're better off at this point than the other guy. He tried drilling and now he's looking for another caliper. He may have a tough find. I'd use a lot of patience or a machine shop. 2 of those to come up with at the same time is not going to be good. I have a stainless steel Speed Bleeder in mine now  ;D  Their info can be found in the chart in Brake FAQ. Good investment. They make bleeding speedy and easy.
« Reply #5 on: January 25, 2011, 09:03:43 PM »
I recall seeing a repair kit for bleeders on the forums recently. It was a brass seat, with the bleeder threaded in. The idea is to drill out the hole in the caliper and tap (tapered pipe thread?) to fit the replacement seat/bleeder. Not sure if there is enough meat around the broken bleeder on your caliper to drill/tap to the required size...??
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7 on: January 26, 2011, 08:27:25 AM »
I'd definitely have to go to a machine shop to do any drilling. I may try some PB Blaster & an easy-out if I have one that'll fit. But for the money and effort it would take maybe I'd be better off just replacing it altogether? I think I read somewhere on here that Golwing calipers were the same as the 750F's - is that right?
Offline gty2k2000
« Reply #8 on: January 26, 2011, 09:24:24 AM »
dear god your right where i was sunday night. ok go to the tool store harbour freight has a set of extractors for like 10 dollars. drill the hole very shallow and use pb blaster once the hole is big enough use and extractor and hope fully it will come out. i as well have a 1976 honda cb750F1 supersport. good luck man let me know on your progress use a torch man its your best freind. and take you time and be carefull!
Offline Toxic
« Reply #9 on: January 26, 2011, 09:49:19 AM »
Heat around the area but not on the bleeder.  Now here is the trick that works for me.  I use a heat gun on high. Then after turning it off, take a can of pressurized air, the stuff you use to clean camera equipement and blow it on the metal bleeder.  It's amazing how cold the air comes out. Do that for 30 or 45 sec then put the screw extractor in, give it a solid whack with a hammer to set the teeth.
And if that doesn't do it ... stop before you bugger it up beyond all repair and take it to a machine shop.
I wouldn't use the compressed air with an open flame, that might be alittle volitile.
bollingball
« Reply #10 on: January 26, 2011, 04:48:51 PM »
You realy want to get it cold turn the can up side down ;)
« Reply #11 on: January 26, 2011, 06:45:12 PM »
may be close but the numbers do not match up. Could be that the 75/76 F has a "stop" for the brake hose where it connects to keep it from rotating. I have some of each.
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: '76 750F rear caliper - couldn't extract the broken bleeder. What now?
« Reply #12 on: February 02, 2011, 08:22:01 AM »
So I went for it last night. MidTNJasonF brought me a heat gun the other night, so after soaking it in PB Blaster for a couple of days, I heated the caliper a good bit, then hit it with some canned air to cool off the screw, then tapped the "best sized" easy-out into it, clamped on some vice grips and gave it a go.. No dice. Tried a couple of different size extractors too and they didn't work. I don't think there was enough of it there to work with.. so much for Plan A.
Offline BeSeeingYou
« Reply #13 on: February 02, 2011, 10:44:47 AM »
The GW calipers are not the same.  They mount on the other side.  The GW rear master cylinder of the early years will work.
Offline jaguar
« Reply #14 on: February 03, 2011, 07:08:04 AM »
you need heat.
heat the hell out of the area around the broken part.
im not a big fan of the sears ez outs that look like drills.
I like the ones that are stubby and fit into a socket.
Offline gty2k2000
« Reply #15 on: February 03, 2011, 12:27:02 PM »
go on ebay i found one through a fellow member on here that sent me one but i was on ebay last night and saw one a replacment caliper for sale on ebay search it out and get that badboy befor its gone
« Reply #16 on: February 03, 2011, 01:28:31 PM »
I don't believe an easy out has ever worked on a broken brake bleeder.  In fact, I think that's bad advice in this case.
I have drilled them out and saved the threads for the original bleeder replacement.  But, it is careful precision work.
You know, you can bleed the system without the bleeder.  You just need the relief hole in the master to become the high point of the fluid system.
All the air will eventually rise to that point and the master piston will pump it into the reservoir.
It's not fast, but it does work, usually overnight.
Depends on your quest to restore vs simply a working system.
Offline BeSeeingYou
« Reply #17 on: February 03, 2011, 05:41:06 PM »
Probably won't work on the rear system as the master cylinder is lower than the bleed screw on the caliper on the 75/6 F.  Now if you parked the bike on a steep incline....... ;)
Never had to drill one of these out but I would imagine you have to match the bit to the inside diameter of the threads in the caliper.  Then somehow pick the remnants from the threads at the same time not damaging the seat.
« Last Edit: February 03, 2011, 05:58:41 PM by srust58 »
« Reply #18 on: February 03, 2011, 07:03:31 PM »
Who said the rear master had to remain mounted for bleeding the air out?  For that matter, the caliper doesn't either.  Just need a block to keep the piston in place.
Offline 78 k550
« Reply #19 on: February 03, 2011, 08:08:17 PM »
I can check on the Goldwing specs for you.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline 78 k550
« Reply #20 on: February 03, 2011, 08:11:48 PM »
If you break a eay out in it you will prob never get it out.
These are hard to find?
especially in my garage. LOL but I'm working on it. I might have a spare.
Paul
« Last Edit: February 03, 2011, 08:14:15 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Roach
« Reply #21 on: February 03, 2011, 08:19:40 PM »
i still think you can get it out!!!!
heat the living #$%* out of it . dont cool it down that defeats the purpose of heating it have the easy out ready
if that wont work cut a groove in the side of the rest of the bleeder nipple. doesnt have to be a huge cut even just a score with a blade to you can rest a chissle on the grove hit it a couple times with a hammer. remember lefty loosy righty tightey. should come out no problem and probably save the threads too!! oh and heat the #$%* out of it before you do this. needs to be really hot
« Last Edit: February 03, 2011, 08:22:19 PM by Roach »
1978 CB550K Cafe Racer
« Reply #22 on: February 03, 2011, 08:25:19 PM »
K550 - sell him a caliper!
« Reply #23 on: February 03, 2011, 08:54:36 PM »
Just speaking from my own experiences, but I have never had success with easy-outs to extract anything seized enough that it broke off. A broken bolt or bleeder can be drilled out; break off an easy-out in the hole, and you're screwed!
Offline Spanner 1
« Reply #24 on: February 03, 2011, 10:15:50 PM »
Tug, your almost there !!.... just drill it out further biggest size without drilling into the threads. The thin wall thats left will then break if pried/ thumped with a straightedge....... turn a bolt of the correct size into the threads to clean 'em before fitting a new nipple....good luck  ;)
