Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Corky, do you have an MPD two piece to trade ? The RC is not my favorite, i have one right now..the drawback to trading would be the throttle shafts are cut between carbs...meaning i would have to place the throttle pulling on the outboard side..
Looking for some cb750 to vm29 intake boots. I hear there are places to buy new. Also Anyone have a nice used set?Also looking for 2 chrome tops for vm29, and maybe a set of new drain plug bolts. Thanks.
USA. Indiana.
Quote from: legbags on September 04, 2016, 07:37:51 PMUSA. Indiana.If you want new try Sudco
Have a rebuilt ARDPolish on the arm is okay, not perfect.Chrome on the head has a "patina" to it.NEW-Coil-Condenser-Points-Cap-Rotor-Gaskets-Seals-Bearings-Drive Belt-Ect ect ectThis is the "later" set up that you can adjust the timing a bit by moving the head.Unit on the right.
