Author Topic: 400$ and a title...ok!  (Read 4075 times)
Offline TMNT
Re: 400$ and a title...ok!
« Reply #25 on: March 05, 2011, 08:04:35 PM »
anyone have a good diagram/pictures/anything of these carbs? Is it difficult to pull these carbs off without going through a lot of problems with syncing?
All this help is much appreciated.
« Last Edit: March 14, 2011, 01:47:24 PM by TMNT »
1978 cb750 Super Sport
Offline BeSeeingYou
« Reply #26 on: March 06, 2011, 01:20:29 PM »
It is not always necessary to remove the carbs and disassemble them.  It may often depend on how gunked up they are.  I have a bike that sat for 25 years and all it took was to remove the bowls to get at the jets/needle valves/ floats.  Cleaned out all the needle valve seats and jets but only one slow jet was clogged.  Have not touched them since.  I would attempt this first before going through the hassle of a complete teardown.  I think the PD carbs are a bit different and you also have an accelerator pump to deal with.
« Reply #27 on: March 06, 2011, 02:09:34 PM »
Yeah, true for most carbs mate, but not PD's.
The pilot jets are pressed in (not screwed in like early K's and F's) and would be impossible to remove and replace with the carbs attached to the engine. No amount of carb cleaner sprayed in their general direction will unblock PD pilot jets, the only way is to remove the carbs, remove the float assembly's and twist the pilot jets out with multi-grip locking pliers, or similar.
The BEST way to clean them is to remove both jets and the airscrews and spray carb cleaner through every orifice to ensure there are no blockages, while the jets are soaking in carb cleaner, (or brake cleaner, my preference) then use an oxy/acetylene torch tip cleaner to make sure the jets are perfectly clear. Then use compressed air to blow through all the orifices to ensure everything is clear before re-assembly, reassemble your carbs, set your float levels, (as per the free down-loadable workshop manuals available in the FAQ section) set your air screws at 1.5 turns out (you're not supposed to touch them because the EPA will get mad, so Honda omitted than information) and "bench synch" your carbs on your coffee table, with a piece of wire.
If it's all too much mate, just send me an air ticket and I'll come over and do it for you. Better make sure your beer fridge is full, cleaning carbs is thirsty work.........  ;)
Offline TMNT
« Reply #28 on: March 14, 2011, 01:38:49 PM »
haha ill pass on that plane ticket...cost more than the bike (and restoring it).
I pulled the carbs. Pulled the float covers and all of the main jets but one were just sitting there loose? Carb 1 looks like it has been stopped up as its rusty colored and the others arent? I will use the tips expressed above first...and will get back. Pictures!
Offline DanielB
« Reply #29 on: March 14, 2011, 01:48:01 PM »
Wow, nice find!
Where in Houston are you located at? I live in Houston also  ;D
1977 CB550K - Project Thread: http://forums.sohc4.net/index.php?topic=80164.0
Other toys: 2003 Cobra | 2002 WS6
Offline TMNT
« Reply #30 on: March 14, 2011, 04:08:37 PM »
northside...jones @ 1960ish.
Offline DanielB
« Reply #31 on: March 14, 2011, 09:26:12 PM »
You live very close! I live off 249 and Northpointe.
Offline BrianAdair
  • Oh, so this is where you type the text...
« Reply #32 on: March 16, 2011, 07:44:35 PM »
Man..... :'(.... why can't I find steals like that...
I paid $500 for mine and it was in boxes.... ;D
Nice bike man ! ;)
Offline TMNT
« Reply #33 on: March 17, 2011, 04:17:13 AM »
Ya That is close. We should ride when I get this thing going.
Nice bike man ! ;)
Thanks!
 stayed in Mineola in 2001 for about 6 months. hah.
