Author Topic: Head Light Vibrates  (Read 793 times)
Offline Tree
  • CB750K5
Head Light Vibrates
« on: January 29, 2011, 05:13:50 PM »
The Headlight lens on my '77 CB550K is vibrating and making an annoying "buzzing" sound when the engine rev's.  If I put my hand on the headlight lens it stops.    It's an aftermarket version as in the pictures below.  I wondered if anyone else has had a similar problem and what I might to about it.
Thanks.
Offline Roach
Re: Head Light Vibrates
« Reply #1 on: January 29, 2011, 06:46:21 PM »
check and see if your adjustment screw isnt soo loose that its vibrating?
1978 CB550K Cafe Racer
« Reply #2 on: January 29, 2011, 06:49:38 PM »
Assuming its not something loose in the sealed beam, tighten the 2 minnie screws that hold the 2 rings together. Then experiment with the 2 that have the cotter pins in them. can't tighten them too tight as it won't be able toadjust. But somewhere in between...
