Author Topic: 550K big bore kit  (Read 2141 times)
Offline juice
550K big bore kit
« on: January 30, 2011, 01:41:35 PM »
Anybody knows where they can be found??
Daily driver: SV1K 2003
In the works: CB550K 1978
Offline crazypj
  • I'm brill, me
Re: 550K big bore kit
« Reply #1 on: January 30, 2011, 03:33:27 PM »
I used modified CB750 pistons when I did mine
Kit's were not easily available in late 70's Britain
« Reply #2 on: January 30, 2011, 08:52:39 PM »
Try 605 kit for the 500, sometimes on ebay
Offline juice
« Reply #3 on: January 31, 2011, 08:07:50 AM »
Crazypj, yeah i'm looking for a complete kit, i'm not in the mood to bring pistons to a machineshop. What do you mean by britain??
bryanj, i've been looking on ebay but never found anything...maybe i'm just unlucky
Offline q2418130103p
« Reply #4 on: January 31, 2011, 02:47:42 PM »
CHeck your PM's
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline juice
« Reply #5 on: January 31, 2011, 04:07:48 PM »
no pm received
« Reply #6 on: January 31, 2011, 04:11:50 PM »
how about now?
Offline crazypj
  • I'm brill, me
« Reply #7 on: February 01, 2011, 01:12:06 AM »
 I mean I did mine in Britain, in 1978 (then rode the hell out of it for 70,000+miles.)
 It's still there, I'm not
Offline juice
« Reply #8 on: February 01, 2011, 10:53:14 AM »
q2418..... received, thanks i'll contact
pj ok i get it. did you resleeve or just bumped the CR??
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #9 on: February 01, 2011, 10:57:10 AM »
What do these two things have to do with each other?
/edit: also, there is only a 2.5mm difference between the bores of the 550 and 750, which I believe is within boring limits of the 550 sleeves.
« Last Edit: February 01, 2011, 11:02:32 AM by mlinder »
No.
Offline crazypj
  • I'm brill, me
« Reply #10 on: February 02, 2011, 12:13:42 AM »
mlinders right, just bore it for 750 pistons.
 You have to fit liners for 1mm over 750 pistons, if I was doing it now I would get a CB750 block and remove liners then bore 500/550 block for oversize liners
« Reply #11 on: February 02, 2011, 04:20:01 AM »
While this sounds a bit odd to me, I believe that many people bor ethe 550 liners for 750 pistons, but rpelace 500 liners for 750 pistons.  Apperently they are different liners?
Offline crazypj
  • I'm brill, me
« Reply #12 on: February 03, 2011, 09:05:22 AM »
500 liners are thinner and won't bore to 61mm. 550 is OK at 61mm but won't 'take' 62mm without liner distorting when it gets hot.
 It works, but not as well as it could
Offline Ricky_Racer
« Reply #13 on: February 03, 2011, 01:40:14 PM »
... if I was doing it now I would get a CB750 block and remove liners then bore 500/550 block for oversize liners
PJ, what issues are involved in doing this in a 550 cylinder block? Thanks a ton!  RR
Offline crazypj
  • I'm brill, me
« Reply #14 on: February 03, 2011, 10:13:12 PM »
put both blocks in oven, wait for clank when they get hot enough to release liners
 Let everything cool down and  measure inside of 750 block and bore 500/550 block to same size (or give it 0.003" smaller than liner)
 Sell 750 bare block to anyone who is doing a  big bore kit
easy peasy lemon squeezy  ;D
