Author Topic: Changing a head gasket difficulty scale?  (Read 2774 times)
Offline guitarkev66
« on: February 04, 2011, 05:33:25 PM »
I need to change a head gasket on my 1971 cb750 are there any tricks I should know about. I did some reading and it didn't seem too hard.  I am somewhat mechanical but new to working on bikes.
1970 K0 CB750 JDM Blue
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Offline hondaface75
Re: Changing a head gasket difficulty scale?
« Reply #1 on: February 04, 2011, 05:42:05 PM »
Pretty sure you gotta pull the motor for that one, unless you've got one of those fancy frame kits.
Offline Skunk Stripe
« Reply #2 on: February 04, 2011, 05:51:29 PM »
You have to pull the motor barring the aforementioned frame mod. There are a couple of ways to do this. Either remove as much from the engine as you can, starter and all that jazz, and heave the motor out. It is heavy, around 170 pounds or so so any weight you lose will help.
You might fashion a bracket to bolt to the motor and use a hoist to help move it out of the frame. You could also lay the bike over and then remove a bunch off the bike and lift the frame off the motor.
Offline bikerbart
« Reply #3 on: February 04, 2011, 06:00:03 PM »
hey if I can do it,you can do it.I was intimidated for a long time because after I moved out west I sold my other bikes so I only had one,and I didnt want to F it up.Just be methodical and take your time.If it werent for this website I wouldnt have had the balls to do it.Then I did it again and it wasn't easier,but,more familiar if you get me.maybe a lil easier,each time it will be.Go for it,its wintertime,nows the time to do it. :)
Offline fmctm1sw
« Reply #4 on: February 04, 2011, 07:19:54 PM »
There's some threads around here showing homemade engine hoists and stuff.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline guitarkev66
« Reply #5 on: February 04, 2011, 07:40:17 PM »
Thanks guys!
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Offline Grabcon
« Reply #6 on: February 04, 2011, 07:58:47 PM »
Try this link form install and removal
http://forums.sohc4.net/index.php?topic=71240.0
CB750   1974 - Gone
CB750F 1976 - Gone :(
CB550   1978 - Gone & now back
CB900F 1981 - Gone
ST1100 1991 - Gone
ST1100 2000 - Gone
VFR800 2008 - Gone
ST1300 2008 - Gone
BMW F700GS - Wife's
VFR1200X 2016 - Mine
Offline octagon
« Reply #7 on: February 04, 2011, 08:13:09 PM »
be aware that it's a tight fit. what worked for me was laying the bike over and lifting the frame away from the motor with a come-along.
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: February 04, 2011, 08:49:00 PM »
It's not so much a difficulty issue as it is a patience and discipline issue.  If you can take your time, follow directions and do things correctly without trying to take short-cuts, you can do it with a minimum of previous mechanical experience.  If you get too frustrated, take a break.
« Reply #9 on: February 04, 2011, 08:54:32 PM »
Uh, sorry, but why do you think you need to replace the head gasket? If it is only a minor oil leak, you might consider just leaving it alone until you really need to pull the motor for a rebuild. (Some have used cotton rope and even tampons stuffed between the fins to absorb the flow. ;) )
Offline guitarkev66
« Reply #10 on: February 05, 2011, 05:30:54 AM »
Good Ideas, maybe I will just let it go.  I was hoping for a trick of being able to change the gasket without pulling the motor, but doesn't seem the case.  The leak isn't real bad I'm just a stickler for the small sh*t!
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Offline dhall57
« Reply #11 on: February 05, 2011, 06:52:09 AM »
My 76 cb750 has the same problem just a very small of oil between the fins at headgasket. This is a common problem with these SOHC. Not really a problem just more of a annoyance than anything. Mine will have to get alot worse before I pull the engine out. Seaweb11 told me about the paper towel trick between the fins at headgasket and no worse than mine is it works like a charm. I put 4 pieces of rolled up paper towel at each corner of head frt. and rear each about 2" long. I use Bounty the quicker picker upper and even painted them silver with some hi-temp paint and its hardly noticeable. I have not had to replace them yet and its been close to a year. Works for me ;D
« Last Edit: February 05, 2011, 07:01:01 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline cb500-1972
« Reply #12 on: February 05, 2011, 01:25:48 PM »
i have a minor "leak" on my head gasket as well. could anyone post a picture and a description of one of these fixes. i have planned a engine maintenance next winter, and would like to get some pointers on how to minimise a leak from the gasket. In my case its one the front left corner
Offline totty
« Reply #13 on: February 06, 2011, 05:22:36 AM »
lookup "oyltite stik" if the leaks only minor and in an accessible place it'll seal.
