Author Topic: Installing a cafe racer seat  (Read 12279 times)
Offline wicat
« on: February 06, 2011, 03:19:42 PM »
Hey guys ive been looking at the seats and i wanted to what do u need to do a cafe seat if i bought one like the fiberglass ones i see around. I see theres an ebay mounting kit that looks like it builds a support for the seat like a floor is this needed or just use the seat?
Offline Fred T
Re: Installing a cafe racer seat
« Reply #1 on: February 07, 2011, 04:51:20 AM »
If you have the original seat, you can use the same bolts, hinges & lock, If you donĀ“t, search e-bay or  parts stores.
I got one for my CB 400 F and only needed foam, upholtery, and a few grommets, everything else was from the old seat.
« Last Edit: February 07, 2011, 05:00:34 AM by Fred T »
Offline Roach
« Reply #2 on: February 07, 2011, 09:59:43 AM »
i cut the lock right off my bike with a grinder made it smooth painted primed the metal.
then i used the rubber original seat grommets as spacers for my cowl and just contact cemented them on let them sit over night and slid a bolt with a big washer through the seat and bolted it down with a nut and washer on the other side. my seat pad covers the bolt and is held down by Velcro
1978 CB550K Cafe Racer
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #3 on: February 07, 2011, 10:30:56 AM »
Is there a fiberglass one that doesn't require cutting and welding the loop to the frame?
music
Offline Roach
« Reply #4 on: February 07, 2011, 10:33:11 AM »
i didnt weld or cut anything for mine...
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #5 on: February 07, 2011, 10:39:28 AM »
Would you mind sharing a link? I made mine out metal but my first attempt is kind of a pos. Won't be able to make another in the foreseeable future.
music
Offline Roach
« Reply #6 on: February 07, 2011, 10:45:00 AM »
http://www.cb750cafe.com/parts.php?id=60
thats the seat i used
then i put it down over top of the original turn signal brackets drilled some whole in the sides and used the brakets to hold the cowl and turn signals on.
Offline Roach
« Reply #7 on: February 07, 2011, 10:46:00 AM »
i dont see any purpose in the hoop unless you are planning on tucking everything under the seat
Offline odiewan
« Reply #8 on: February 07, 2011, 10:46:49 AM »
I got a fiberglass seat from Steve Carpenter (Carpy)
http://www.cb750cafe.com/parts.php?id=109
I should be able to use the stock hardware. I didn't have those pieces so I fabricated some. Mainly to give the seat nice support.
Here's what I did, for what it's worth.
http://forums.sohc4.net/index.php?topic=78987.msg926525#msg926525
CB750K3
2009 Aprilia RS125
2001 Aprilia RSV Mille R
2002 Suzuki SV650S
1979 Vespa P125X
Offline kajtek
« Reply #9 on: February 07, 2011, 10:49:22 AM »
i just cut the hinges/ lock off and use heavy duty velcro to hold the seat in place..
1978 honda cb400f supersport
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #10 on: February 07, 2011, 10:57:40 AM »
Thanks guys. That's a relief. I'm going to hunt around a bit and see what I find.
music
Offline Shoeboxjoe
  • Large Breasts
« Reply #11 on: February 08, 2011, 09:07:15 AM »
I ended up cutting/grinding off the rear fender mount and the hinges for the stock seat, welding some tabs to the frame with nuts, building an aluminum support for the fiberglass seat with shims and rubber pads that rest on the frame, and using 4 flush headed allen bolts to bold the seat and support to the frame. Then the seat pad velcros to the fiberglass seat covering the bolts. It was a pain to get everything lined up and shimmed and then to remain that way through welding and epoxy and all that crap. It came out perfect but if i had to do it again i think i would try different methods.
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
