Author Topic: Do you think I could cure VHT with a 1600 watt IR lamp?  (Read 2733 times)
Offline q2418130103p
« on: February 06, 2011, 06:09:14 PM »
I was just curious, I have one of these big IR 1650 watt lamps in the garage.  Do you think it would work to cure VHT paint?  They get awfully hot, but I would likely need to go section-by-section.
http://www.infratech-usa.com/automotive/productDetail.php?id=8
« Last Edit: February 06, 2011, 06:23:24 PM by q2418130103p »
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Offline faux fiddy
  • bike in a box
Re: Do you think I could cure VHT with a 1600 watt UV lamp?
« Reply #1 on: February 06, 2011, 06:21:14 PM »
You mean infra red? 1600 watts it a bunch. Great for warming up do-nuts.
Use with care and supervision, and not too close. You don't want things to dry too fast either.
I used a bulb type  heat lamp on a paint project one time to enhance drying time. Even   two feet away or a little more it was a bit hot. They seem to focus the heat. I turned my back (or left for an hour) and some of the old finish was turning to charcoal.
Found out this was also a good way to remove the old finish.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #2 on: February 06, 2011, 06:23:02 PM »
You mean infra red?
oops.  Yes, Infrared.  I will fix my post.
This thing is very strong, I think you could melt donuts with it.
« Last Edit: February 06, 2011, 06:25:03 PM by q2418130103p »
Offline DarcyCB400F
Re: Do you think I could cure VHT with a 1600 watt IR lamp?
« Reply #3 on: February 06, 2011, 06:37:15 PM »
Looks like an Infratech lamp... check with the manufacturer to see what kind of metal temp they can produce. 800-421-9455
Perhaps it would work! VHT might have some helpful advice on their website too about using IR lamps.
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
« Reply #4 on: February 06, 2011, 06:43:01 PM »
Yeah, its a infratech.  I will try to get in touch with one of them during the business week.
It would certainly be nice to know. how easy would it be to paint some parts and put them under the lamp.  That way I dont have to explain why there are bike parts in the oven.  I already have to explain why there are tires behind the couch, and a box of gaskets next to the TV.
Offline faux fiddy
  • bike in a box
« Reply #5 on: February 06, 2011, 07:02:56 PM »
Not to mention grease in the sink.
« Reply #6 on: February 06, 2011, 07:06:40 PM »
hah, I was trying to figure out today how I was going to explain the ring of oil around the tub after I soak my cases post-sodablasting.
Offline faux fiddy
  • bike in a box
« Reply #7 on: February 06, 2011, 07:43:24 PM »
Just don't tell her you love your bike...
« Reply #8 on: February 07, 2011, 03:51:54 PM »
I have to say to her "dont worry, it's just machine" and I whisper to the bike "dont worry, i didnt mean it".
I was thinking, many people use the heat of the engine to cure the paint.  Even if the IR lamp cant completely cure it, possibly it can solidify it enough to make mounting the engine without leaving prints easier.
Offline Scott S
« Reply #9 on: February 08, 2011, 06:52:25 AM »
 Is this for the engine and/or header? I've had good luck with just letting it air dry and then curing it with engine heat whenever I got the bike running.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #10 on: February 08, 2011, 06:55:47 AM »
Cylinders and cases
Offline Kong
« Reply #11 on: February 08, 2011, 07:43:34 AM »
You must be young and new at this - I could explain that ring away without breaking a sweat.  That's like coming home at 10:30 on a friday night a little tipsy.  What I'm afraid of are those nights when you come home at Zero-dark-thirty stumbling drunk and smelling like somebody she don't like. Now that's a problem.
OK. On the self induced oil slick.  First off I assume she who must be appeased was not home when you did this.  It almost sounds funny to have to say it.  Anyway, she's gone and you trash the place, and now you're looking for an excuse 'cause she's sure to come back home sooner or later and you haven't figured out any way to hide what you've done.  That much is understood.
Now, if she finds out you stuck the engine in the bath tub, that's ain't gonna play well.  You did it and the evidence is there (the oily ring) but at the moment all she knows is that there is an oily ring, she don't know it was your baboon-butt that suck an engine in there to get it that way.  Now you want to come out of this in the best possible light, and I assume that if she if the vixen we suspect she appreciates a resourceful but clean man.  You upright-walkers are funny like that.  So what you need to do is somehow link the evidence that she is sure to find with the facts you wish to present no matter how preposterous the nexus may be.  Any Republican can show you how to do this.  Now if you are willing to actually lie to do this or not is up to you, but here's the story.  You tell her that the ring in the tub came from you cleaning up (taking a bath) after a hard day disassembling, cleaning, and reassembling the engine out in the garage.   She likes a guy who can do that kind of work and she likes a clean guy - two birds with one stone.  You could even add some validity to this story by actually taking a bath, but that's optional.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
« Reply #12 on: February 08, 2011, 07:48:08 AM »
That is an excellent cover up, however I could never it a hundred years convince her that I took a bath...
Offline faux fiddy
  • bike in a box
« Reply #13 on: February 08, 2011, 08:35:55 AM »
Wish I was so lucky. Spent the weekend with a rented sewer snake fishing for  brown trout. If I take a bath it will come up through the toilet if it goes anywhere, along with whatever else is down there.
Hopefully the plumber's machine is better and can fix it and that  it's not a collapsed line.
« Last Edit: February 08, 2011, 08:39:14 AM by tree fiddy of industry »
Offline bradweingartner
  • 74 CB 550 x2
« Reply #14 on: February 08, 2011, 08:56:25 AM »
Easy. The drain was plugged with all of her hair and as you were showering the tub filled up. Not only are you a clean man, but now you're a handy clean man because the tub is no longer plugged.
Offline Kong
« Reply #15 on: February 08, 2011, 09:12:31 AM »
You sir are a bona fided genius, not only have you managed to get credit for saving the day but also transferred blame to the other party involved.  Genius I tell you, $%^ed genious, there is no other word for it.
1978 Honda CB550K
1977 Honda CB550K
Offline faux fiddy
  • bike in a box
« Reply #16 on: February 08, 2011, 09:28:05 AM »
I met some Democrats that are very good at this also. I think its more when  any politician  involved is very good at this.
Offline lone*X
« Reply #17 on: February 09, 2011, 11:28:59 AM »
I must be well "trained".  I usually just clean up my messes instead of waiting to be caught.  Yes, just a little Soft-Scrub and a sponge and go at it.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
« Reply #18 on: February 09, 2011, 11:58:18 AM »
ahhh...just sprinkle some dorito crumbs on it and call it good   ;D
« Reply #19 on: February 12, 2011, 07:10:59 PM »
do you think she will notice?  even if she does, i dont think she will expect what is going to happen next:
I tried to make them blend in with the weights...
Step 1 is over, the cases are in the house.  Step two, get them in the tub.
« Last Edit: February 12, 2011, 07:14:05 PM by q2418130103p »
