Author Topic: Throttle Valve Stuck  (Read 1032 times)
Offline Nabors12
« on: February 10, 2011, 05:52:04 PM »
Reassembling my bike after a complete tear-down and I have it all back together with cables and all, but come to find out my throttle will only turn about 10%. So I open up the tops of the carbs and realize the throttle valve on carburetor 1 is completely seized in the shaft. Is there any tips for getting this thing out? I have sprayed the crap out of it with liquid wrench but it still won't budge.  ??? ??? ???
Thanks
Re: Throttle Valve Stuck
« Reply #1 on: February 10, 2011, 06:26:44 PM »
Heat gun on the carb body where the slide is.  That's hot air, not open flame.  When it is hot give movement a try, it should budge and your spray lube should keep it limber.
However, if it dries out again it will stick again.  For a more permanent fix, you'll have to remove the slide from carb body and clean the "glue" off both.
Offline Nabors12
« Reply #2 on: February 10, 2011, 10:14:37 PM »
Thanks, Ill give that a try as soon as I get my hands on a non flame heat source.
verstellung
« Reply #3 on: September 09, 2011, 08:57:03 PM »
I realize this is an old post; however, I was having the same problem with 3 of my throttle valves ( '75 CB550)
Like Nabors, I soaked the living &*!$% out of them with SeaFoam Deep Creep to no end.
Tried the heat gun and   PRESTO  that SOB slide right out.
Thanks TwoTired!!
/ verstellung
