Author Topic: Post your Dyno Graphs here.  (Read 96411 times)
Re: Post your Dyno Graphs here.
« Reply #125 on: May 31, 2014, 06:05:03 AM »
Guzzi does have 40mm dellortos (not 100% sure, will ask and correct if wrong). for the next races a slightly less radical camshaft will be incorporated -> 2hp loss but useable torque from 4000rpm.
i have done a radical weld Job on the Guzzi heads, Peter did the final porting. at the first glance really rough and ugly ports, but the result tells another story.
kawa does have 37mm CRs.
mec
hi mec
very nice result form the guzzi. how many CCs is it? I am pretty sure that even the guzzis of Motobel and Taurus Team are not doing 123hp.... more like 115, but they are endurance motors, so a bit less stressed.
interesting work on the head, just what i did to my 90hp Gpz810, good squish is really important.
What pistons are fitted in that guzzi? regular high compression will not work so well with that kind of flat & large squish areas. can you post some pics?
Will ask for more data when i start working on my le mans III.... one day...
That would be interesting to see. Those welded chambers look like Branch Harley heads. The Branch heads have had problems with hardness after pouring all the weld into chamber....the heads can blow out at the fire ring. I have seen several sets that have done this.
Offline turboguzzi
« Reply #126 on: May 31, 2014, 01:06:15 PM »
maybe they should use guzzi heads on those harleys :)
« Reply #127 on: May 31, 2014, 03:58:15 PM »
It couldn't hurt. ;D Keep in mind the hardness. It is a good shape but... just something I've seen over the years.
Offline Old Scrambler
« Reply #128 on: May 31, 2014, 05:46:03 PM »
Scotty..........many enjoyable miles I've had on an FT.................gave one to my daughter to ride.........and ride she did.............and then I sold it for more than I paid :)
There are a few FTs that show up at AHRMA events with 600cc motors.  They need help to get them started ;) ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online scottly
« Reply #129 on: May 31, 2014, 08:32:14 PM »
I've put about 20 miles on the FT since pulling it off the dyno, half on-road at speeds up to 65 MPH, and half on dirt roads at speeds as low as 15 MPH. I'm very happy overall with the way it's running! ;D ;D
Online scottly
« Reply #130 on: June 02, 2014, 10:08:09 PM »
Thanks guys. Previously I had to unstrap to get outside to bump start, then idle it to get back in and strap the front down. Finally finished my roller starter which will save all that fooling.
Lard ass isn't an issue Mike, I'm the one sitting on it.  ;D  I may try a few pulls with the rear synched down some.
The only thing I notice is it seems to polish the rear tire which I thought might be traction loss, but I suppose that is likely not the case.
Evidently my lack of a lard ass is an issue. :o Note the bobbles in the torque curve at the top end; finally realized the tire had been spinning on the drum when I noticed a build-up of rubber dust on the deck behind the drum.
TRW 836, mystery regrind cam (about .320" lift at the valve), stock K1 head, Weber carbs, and Gerex ignition.
Offline turboguzzi
« Reply #131 on: June 03, 2014, 04:43:33 AM »
scottly, what gear do you run in dynoing?
going with 4-5th will limit wheel spin.
another detail is to adjust the bike position so rear wheel axle is just a bit ahead of the drum's so it creates a bit of wedge effect/extra downforce.
Offline johno
« Reply #132 on: June 03, 2014, 05:42:26 AM »
Dont worry Scott, first time I dyno'd a dirt bike with nobby tires I covered the room in flying knobs, it was wild,  :o :o :o
 when dynoing the Jawa speedway bikes running on methanol we used to play "last man to leave the room was the winner " and closed the door.   wild man, tears of joy :o ;) ::)
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline frodef2
« Reply #133 on: June 03, 2014, 05:56:56 AM »
Just came back from dynoing my friends ZX12R
I helped him install the Nitrous kit
Modifications are:
Muzzy uprated fuelpump
Powercommander 3 usb
Powercommander Ignition module
Powercommander Multifinction hub, for the mapswitch ability.
Dynatec ARC-2 for the launch control.
Nitrous RPM window switch.
MPS 40hp Nitrous kit
The reason for the mapswitch is that Drag bikes in the SuperGas class in Sweden aren't allowed to use nitrous for some reason.And they are allowed in norway.
The bike already ran ~9.65 on the 400 without the nos.
Im sneaking in a little picture of the bike from last summer at Sundsvall raceway in Sweden
76' Supersport
Offline turboguzzi
« Reply #134 on: June 03, 2014, 06:29:53 AM »
Gulp! talk about who has the biggest...
Offline mec
« Reply #135 on: June 03, 2014, 10:35:34 AM »
or send it to me for a weld Job :)
btw: Guzzi Piston Picture below, do not know the brand however.
2nd btw: plans are to race These Guzzi(s) in the 4hours of misano.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline 01Thomas
« Reply #136 on: June 03, 2014, 01:45:09 PM »
Mec, I have two classic roundfin Guzzi big twins and to me, from this angle, that could very well be a stock piston.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline turboguzzi
« Reply #137 on: June 03, 2014, 02:50:29 PM »
with it being a Horvath guzzi motor, you can bet these are not stock pistons....
MEC, whatever happened to his Concam motors? wonder what kind of power they made.... maybe you dynoed it? :)
If you mean the october 12th race, then i'll definetely be there, hopefully with my supermono for our national series
Online scottly
« Reply #138 on: June 03, 2014, 08:04:32 PM »
That run was in 4th gear, and I shut it down at about 6.2K RPM, as this was just a first-test run. The torque number is completely bogus.
The axle was centered on the drum; next time I'll shift it forward.
BTW, the last time the top end of this motor was touched, other than tappet adjustments and removing the cam cover was 1979. I'm guessing the best the old girl has may be around 65 RWHP, but I can already see the Webers need some serious attention.
Offline mec
« Reply #139 on: May 31, 2015, 11:14:04 AM »
dyno time:
interesting for our vintage racers, dyno graph from a 2valve guzzi engine running on 100octane fuel
currently 2nd in the italian vintage endurance championship.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline mec
« Reply #140 on: May 31, 2015, 11:19:29 AM »
another one,
my Rotax Mono Racer, again running on 100 octane fuel, 72hp and 105kg dry weight.
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline 01Thomas
« Reply #141 on: May 31, 2015, 02:46:09 PM »
120-something from a two-valve Guzzi on 40mm dell'Ortos is very, very very impressive! And at relatively low revs too. Please tell this Guzzi rider & owner more about it?
I'm bl00dy envious!
« Reply #142 on: May 31, 2015, 04:25:52 PM »
I'm bl00dy envious!
+1, very good numbers, that supermono with 72hp and 105 KG's would be fun too... 8)
Offline turboguzzi
« Reply #143 on: June 01, 2015, 08:00:21 AM »
another one,
showing off MEC? problem is there might be somebody with a bigger bump out there... :)
my XTZ 680 supermono's dyno: 77 rwhp, not sure about dry weight, but with battery and oil its 125.
MEC, are you actually racing it? my championship has a supermono class but  not that many participants so we are mixed with other classes.
could be fun to race it with other supermonos...
BTW, hope you have some protection for your family jewels.. ;) those carb throats sure look close!
good luck for your friends from Horwath in Vallelunga
« Last Edit: June 01, 2015, 08:07:37 AM by turboguzzi »
Offline mec
« Reply #144 on: June 01, 2015, 11:13:22 AM »
hi TG,
nice numbers for your XTZ. engine concept from 1991 approx?
thats the problem with my liquid cooled rotax head, concept from stoneage or so...
Daiber et uno once had +90hp with this head, but: the head cast, sawed into pieces, welded together, milled,....thats more work i am willing to do :)....+70hp reliability is the next issue.
maybe i will build one more engine: air cooled head with double in-ports. should be good for ~70hp.
the liquid cooled rotax is raced from time to time (liquid cooling is not allowed in the GrabTheFlag series). last weekend we had our first rollout in rijeka. my friend robert (he has three children, the carbs are no danger any more) raced the bike. 3 races, 3 victories. racers level not in the MotoGP class however.
next race for the dohc rotax will be Rupert Hollaus Gedenkrennen Reb Bull Ring, Austria. the aircooled one races at GTF Slovakiring (end of June).
have a nice time
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline voxonda
« Reply #145 on: June 01, 2015, 11:56:01 AM »
Standard 736 (still), oem cam, good yoshi style pipe and CR31, Accent electronic ign and Dyna coils. End result little over 70 hp at the rear.
Rob
Offline gschuld
« Reply #146 on: June 01, 2015, 12:22:21 PM »
Nice Rob.
I love that you are giving good data regarding stock based 736 motors.  It will be interesting to compare with the Yoshi pistons. Having a good compression check might give some insight to how well the stock piston ring/ cylinder bore seal is holding up.  I recall Honda man suggesting a few times that power levels can increase noticeably with the same stock piston/cylinder parts but with a fresh hone and rings.  That could be taken into consideration when judging the power difference between the stock (ish) setup and the yoshi piston/ fresh bore, hone and rings refresh.
Please keep us updated.
George
« Reply #147 on: June 01, 2015, 12:26:31 PM »
Rob,
What year/model 736 engine?
Online PeWe
« Reply #148 on: June 01, 2015, 01:12:05 PM »
I posted these in another thread earlier not in this dyno thread.
Offline voxonda
« Reply #149 on: June 01, 2015, 01:44:39 PM »
Rob,
Jerry,
1975 engine. So not the best hp output engine in theory.
Rob
