Author Topic: Post your Dyno Graphs here.  (Read 101985 times)
Re: Post your Dyno Graphs here.
« Reply #150 on: June 01, 2015, 02:46:18 PM »
75 F or K ?
Offline voxonda
« Reply #151 on: June 02, 2015, 12:17:34 AM »
« Reply #152 on: June 02, 2015, 10:28:36 AM »
WOW!!
Offline turboguzzi
« Reply #153 on: June 03, 2015, 05:09:51 AM »
pewe, rob, nice numbers indeed.
MEC, yes it's based on the 1991 5 valve head.
a nice anecdote,  i manage to talk with one of the guys that in the 90's was working for yamaha belgarda, he built the engines for the italian championship winning BYRD machines as well as the "works" MZ Scorpions. He told me that in the five valve head the three inlet valves actually disturb the flow of each other, so not that good. The guys i brought the engine from in holland have now moved to a four valve Yamaha and said that immediately the hp numbers where  much better, like in the mid 80s.....
Offline voxonda
« Reply #154 on: June 03, 2015, 05:27:50 AM »
Touch the pic with mouse for a short movie.
One of the runs.
Rob
« Last Edit: June 03, 2015, 10:01:52 AM by voxonda »
Offline mec
« Reply #155 on: June 03, 2015, 01:40:15 PM »
does not make me wonder at all, considering the way 5valve heads have gone in formula 1 (yamaha, ferrari). nevertheless a courageous try from the point of view in mid 80ies.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline turboguzzi
« Reply #156 on: June 17, 2015, 06:26:53 AM »
mec
mec, check your pm's...
Online scottly
« Reply #157 on: June 29, 2015, 07:37:44 PM »
I've been doing some work on the "ditch pump" FT500 lately, like adding a mild White Bros cam and 36mm Mikuni from an XR, and an exhaust cobbled together from spare bits and tubes cut from a Kawi 550 aftermarket pipes. The exhaust was responsible for the greatest amount of increase, as the stock header is extremely restrictive.
Offline simon#42
  • liverpool
« Reply #158 on: July 02, 2015, 12:53:01 PM »
it must have made less power than a lit fart before you started scotty
why oh why do people have these stupid projects , anyway must get back to the 100hp bmw r100 i have been working on .......... well it will make 100hp one day , possibly . although after 10 years i may be wrong .
« Reply #159 on: July 02, 2015, 03:58:04 PM »
 ;D
Online scottly
« Reply #160 on: July 02, 2015, 10:17:46 PM »
This has been a fun project, Simon, as well as an educational experience. ;) Between the restricted air intake and the restricted exhaust, Honda threw away a good portion of usable power. The FT now reminds me of a BMW RS 900; smooth pulsations of torque, without the annoying side-to-side rocking motion. ;D
Offline simon#42
  • liverpool
« Reply #161 on: July 03, 2015, 10:39:55 AM »
i love the side to side rocking motion scotty , if i can feel it it means i havnt blown another engine .
Offline mrfish2
  • I might be a
« Reply #162 on: October 16, 2015, 08:08:39 PM »
Decided to dyno my mostly stock CB550 to get a baseline before planning a future big bore build. The only engine upgrades are a CB650 cam and MotoGP Werks exhaust, everything else is pretty much stock besides the jetting for the exhaust. It ended up putting down 37 HP and 25 ft/lbs of torque at the wheel.
« Last Edit: October 16, 2015, 08:13:05 PM by mrfish2 »
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #163 on: June 04, 2016, 05:32:32 PM »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #164 on: June 17, 2016, 01:33:59 PM »
A couple of runs from last week. Going do better.Bill
BentON Racing Website
BentON Racing Facebook
« Reply #165 on: June 17, 2016, 01:37:40 PM »
Looking good Bill..
« Reply #166 on: June 17, 2016, 05:27:37 PM »
More 750 records for Brian!
Offline flatlander
« Reply #167 on: June 18, 2016, 03:48:13 AM »
mrfish2, good idea to do a before/after!
here's my CB550F with the below works.
graph is from about 400km after assembly.
pistons: wiseco 59mm 10:1 CR
cylinder top decked -0.004in
MLS head gasket 0.030in
head:
mike rieck porting stage 2+
-0.004in decked
serdi cut valve seats
+1mm intake valves
tapered guides
kibblewhite valves/springs/ti retainers
camshaft: megacycle hardweld 126-00
intake manifolds matched to ports
carbs: stock 069A
original airbox, with stock airfilter
exhaust: original 4-into-1
ignition: boyer-bransden micro power
« Reply #168 on: June 18, 2016, 05:44:14 PM »
 If you has some cam in there Jan that would have kept climbing. Notice how the power doesn't drop off.
Offline flatlander
« Reply #169 on: June 18, 2016, 11:42:49 PM »
mike, are you talking to me (attila) or some guy called jan?
if it's me: no doubt with a 126-20 you could get more out of it but i did not want to sacrifice torque as it's for a street/touring bike. we had quite a discussion about this last year if you remember.
Offline Ilja
« Reply #170 on: June 26, 2016, 02:24:21 PM »
Here's a graph of my cb with the hair dryer on at 0.7bar. (10psi)
I had some detonation issues before as the compression was too high and squish was off, so above 8k you can see that the engine is misfiring (or detonating).
Didn't hear a thing in the dyno room, but could be that one piston already had blown ringlands from the first few rides I did with a 1bar stock wastegate and failing boost gauge...
Working to get that fixed now and then it's back to the dyno with 1bar & an intercooler to see what she really has to offer.  :)
« Last Edit: June 26, 2016, 02:49:29 PM by Ilja »
    • BentON Racing
« Reply #171 on: June 26, 2016, 05:18:29 PM »
Nice numbers, gotta love forced induction!
Online scottly
« Reply #172 on: July 23, 2016, 01:55:42 PM »
Thanks guys. Previously I had to unstrap to get outside to bump start, then idle it to get back in and strap the front down. Finally finished my roller starter which will save all that fooling.
Lard ass isn't an issue Mike, I'm the one sitting on it.  ;D  I may try a few pulls with the rear synched down some.
The only thing I notice is it seems to polish the rear tire which I thought might be traction loss, but I suppose that is likely not the case.
Evidently my lack of a lard ass is an issue. :o Note the bobbles in the torque curve at the top end; finally realized the tire had been spinning on the drum when I noticed a build-up of rubber dust on the deck behind the drum.
TRW 836, mystery regrind cam (about .320" lift at the valve), stock K1 head, Weber carbs, and Gerex ignition.
Bump for Ron...
« Last Edit: July 23, 2016, 02:03:28 PM by scottly »
« Reply #173 on: July 23, 2016, 04:15:46 PM »
Comparing yesterday to June runs. I did a little ignition timing corrections and went to 125 from 122.5 mains. Picked up a little HP on the way up, with a bit more peak. And a little bit more torque on the way up, lowered the peak RPM a skosh.  I'm just happy it didn't go backwards. It's a little rich, but the Mikuni manual says that's about right.  A little rich will help it run cooler if that's a concern.
« Reply #174 on: July 23, 2016, 05:42:11 PM »
Attila.....I was speaking to you. I forget names sometimes. ;D I do remember corresponding with you about torque etc and that was your goal. Larger cams will always change torque etc unless you pump more static compression into the engine. I just would have liked the engine to make 7 or 8 more HP. On the other hand....the power just comes on early and stays. I am just an HP junkie. ;D ;D ;D
