How about this to get from that to that?
6/5/09 – bought for $100
6/9/09 – purchased tank for $100
6/16/09 – title bond & title for $82
6/19/09 – clubman bars for $30
6/22/09 – right hand control $27
6/23/09 – carburetor rebuild kit $73
6/23/09 – fuel petcock and line $53
6/23/09 – footpegs $11
6/29/09 – spark plugs $10
7/4/09 – ignition $30
7/14/09 – (2) oil filters $10
7/14/09 – oil drain plug $14
7/14/09 – carb pump diaphragm $34
7/17/09 – pod air filters $35
8/17/09 – front brake master cylinder $30
8/17/09 – ignition coils $36
11/13/09 – choke cable $17
11/25/09 – oil lines $30
12/22/09 – more oil lines from Carpy $72
1/15/10 – battery $48
1/21/10 – grips $18
2/1/10 – front wheel/tire/rotor $85
2/3/10 – seat $75, resold and netted $60 after shipping
2/5/10 – exhaust can $20
2/10/10 – pull throttle cable $20
2/14/10 – airbox, boots and filter $75
3/6/10 – forks and headlight brackets $60
3/11/10 – carb bolts $18
3/11/10 – fork boots $30
3/13/10 – tires and tubes $240
3/30/10 – wiring harness and right side cover $60
6/2/10 – café racer seat $425
6/16/10 – carb boots $35
7/1/10 – speedo sender $15
7/14/10 – fork seals $15
8/3/10 – left side cover $45
12/14/10 – clutch cable, cable adjuster, tach cable, oil drain plug, oil filter washer, oil filter bolt, plastic coupler, rear brake shoes, exhaust gaskets, front master cylinder - $167
12/16/10 – gas tank rubber mount $23
12/16/10 – front brake line and hose $65
12/30/10 – front brake calipers $103
1/4/11 – front brake piston o-ring and bleed valve $37
1/11/11 – front brake pads $30
1/13 – mirrors $11
2/3/11 – tappet covers $38
2/12/11 – points, electrical connectors $37
Total to date: $2529
