Author Topic: Wheel Bearing retainer install  (Read 1103 times)
Offline 70cbk0
« on: February 14, 2011, 11:04:22 AM »
Got mine out fine, (thanks to all the threads on here, thanks guys!) Now that I'm going to re-install, how many people re-punch them, to make them stay in, OR is Lock-Tite a suitable substitution? Thank, John. (CB750K0)
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Re: Wheel Bearing retainer install
« Reply #1 on: February 14, 2011, 11:09:34 AM »
I had the same quandary. Decided LockTite even the soft stuff, is there regardless. The stakes are there, then gone with drilling. I went with staking. Got a tiny punch and did it. Only 2 though, not 4. 4 seems overkill.
Offline Kong
« Reply #2 on: February 14, 2011, 11:13:08 AM »
I just put mine back together last night, I didn't do either.  I guess I should go hit it with the punch, once will be enough.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline lofton05
  • 76 CB750F
« Reply #3 on: February 14, 2011, 01:56:47 PM »
+1 on the punch
Offline 70cbk0
« Reply #4 on: February 14, 2011, 02:32:37 PM »
Ok thanks guys 3-0 on the punch
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
Offline Popwood
« Reply #5 on: February 14, 2011, 06:43:48 PM »
Just curious. Honda did four stakes and one can reasonably assume it did the engineering behind it. The suggestion here is to do less, based on what? Maybe Honda was just covering it's butt, but wouldn't a rider/ mechanic do the same, if not more so since it's HIS butt?
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline donpark1086
« Reply #6 on: February 14, 2011, 06:50:03 PM »
What about a dot of red paint on the edge after installing with a good firm torque.  A glance at the red dot will indicate all is good or loosening.  But it does take a memory for a pre-ride check.
Offline 70cbk0
« Reply #7 on: February 14, 2011, 07:07:40 PM »
yes, some had 4 stakes, and some were 2 stakes, (front wheel maybe) and you're right, they had a reason, I guess I'll do the same. But there IS something archaic about pounding on it so it won't loosen! I'm kinda thinking that the lock-tite would likely be fine....
1970 CB 750K0
1969 CB 750K0
1966 CB77 Superhawk
1982 Honda XR200R
« Reply #8 on: February 14, 2011, 07:14:00 PM »
My point was that the locktite will interfere with the next maintenence done by you or the next owner. You may become that cursed PO.   ;D
While the staking drills out and the retainer comes off un-impeded.
Offline srbakker
  • Spam & Eggs
« Reply #9 on: October 27, 2011, 07:38:47 PM »
So here's a question... Exactly HOW do you restake this thing?  I've been confused since I started reading these threads.  Please enlighten me!
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
« Reply #10 on: October 27, 2011, 07:48:36 PM »
Take a center punch, the one with the point on it. Set the point in the crack where the threads of the retainer meet the threads of the hub (where the original stake was, just offset a little into some fresh area). tap the chisel a few good whacks, to where it goes down about 3 threads worth. That will bung the threads enough that it won't turn. And you can drill it out again later. Easy Peazy, don't overthink it.
Offline srbakker
  • Spam & Eggs
« Reply #11 on: October 27, 2011, 08:32:22 PM »
Cool, many thanks.
1975 CB750 K5
2007 Triumph Tiger
