Author Topic: CB750 K8 accel pump cover supposed to have this hole?  (Read 1136 times)
Offline tedone
« on: February 14, 2011, 07:36:14 PM »
I am rebuilding the carbs on my CB750k8. Can someone tell me if the accellerator pump cover is supposed to have this hole in the bottom or did a previous owner modify? Im thinking that it shouldnt be there, if not do you think I could close it up with JB Weld after
Getting the check ball and spring freed up?
This is my 1st post after lurking for a few months, so hopefully the picture post correctly.
Thanks.
Offline Hasenkopf
  • Really, I'm not an
  • This space for hire.
Re: CB750 K8 accel pump cover supposed to have this hole?
« Reply #1 on: February 14, 2011, 08:08:26 PM »
does the hole go all the way through ?
I like berries.
Offline tedone
« Reply #2 on: February 14, 2011, 08:16:31 PM »
Yes, I can push on the check ball through that bottom hole.
Ted
Offline Hasenkopf
« Reply #3 on: February 14, 2011, 10:15:42 PM »
instead of doing anything to that one, like plugging the hole, maybe it would be better to find an unmolested one?
I like berries.
bollingball
« Reply #4 on: February 14, 2011, 10:29:05 PM »
No that hole is not supposed to be there. If you are taking the check valve apart you MAY be able to fix it. The problem is it has to cup shaped inside for the ball to sit in. looks like someone tried to drill it out probably from the inside and went to far :(
Offline Hasenkopf
« Reply #5 on: February 14, 2011, 10:31:56 PM »
that was my thought, but mine is still buried under three feet of snow... :(
I like berries.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: February 15, 2011, 03:49:46 AM »
I'll check the pump housing on my 78' 750 tonight and let you know for sure.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline tedone
« Reply #7 on: February 15, 2011, 04:18:03 AM »
Thank you for the replies.
Bollingball, I think you may be correct.
I have used the HONDACHOPPER SITE and disasembled. I looks like the seat area may have been affected too. As the seat is not even all the way around where the ball sits.
I will probably have to replace.
Thanks, Ted
bollingball
« Reply #8 on: February 15, 2011, 04:21:42 AM »
I'm telling you for sure now :D. that is the fuel side of the valve it will leak.
