Author Topic: Reproducing a CB frame in Aluminum?  (Read 3559 times)
Offline P_Camps
« on: February 17, 2011, 09:30:01 AM »
I understand the frames on our CB's are Steel frame.
Aluminum Frame. can it be done/reproduced?  Has anybody ever done it.
1978 CB550
Offline Roach
Re: Reproducing a CB frame in Aluminum?
« Reply #1 on: February 17, 2011, 09:33:14 AM »
sure it can be done any thing can be done with the right tools and know how. Have i seen it done no. but doesnt go to say that someone hasnt tried and just not recorded it. it sure would lighten things up. to keep the same styling it would probably need alot more gussets.
1978 CB550K Cafe Racer
Offline odiewan
« Reply #2 on: February 17, 2011, 10:42:28 AM »
The other thing that it would probably require is either thicker tube walls, larger OD tubes or both to get the right stiffness. But it does sound like a great idea.
CB750K3
2009 Aprilia RS125
2001 Aprilia RSV Mille R
2002 Suzuki SV650S
1979 Vespa P125X
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: February 17, 2011, 12:20:42 PM »
If you are going to go to that trouble just do a repro in titanium, you wouldn't have to increase the diameter and it would be way stronger.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #4 on: February 17, 2011, 12:43:57 PM »
You wouldn't want to build an aluminum replica of an old basket frame like ours.
Aluminum breaks, mild steel flexes. You'd need about 40% thicker alu to attain the same flex and yield properties of steel.
Steel also has higher energy absorption properties. Aluminums fatigue properties are much worse than steels.
This is why alu frames are designed completely differently than steel frames.
No.
Offline fatmatt650
  • Part Deux
« Reply #5 on: February 17, 2011, 02:26:22 PM »
Oooohhh. A Ti frame would be very sexy. 8)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #6 on: February 17, 2011, 10:13:26 PM »
4130 chromoloy would be the ticket.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline xedge4lifex
  • Trillz McGillz
« Reply #7 on: February 18, 2011, 12:23:42 AM »
+1
i went into researching this last year for a couple months, and it would take ALOT of work. im sure one of the guys on the forum knows. even the big boy vintage frames cb750s kz900s probably dont weigh more than what like 50 pounds? my buddy raced bmx for about 12 years and had a huge collection of frames. the carbon fiber frames had these chromoly gussets to connect the tubes visualize a T fitting if you will. and that frame probably weighed about 5 pounds? it would take some serious thinking to build a frame out of carbon fiber tubing and those gussets, buts you would be looking at like a 15 pound frame. swellguy has it chromoly will be the lightest, and give you that shiny look to get all the honeys
Wake up, look up, there's a warmth up there
a reminder of peace, a reason to care.
« Reply #8 on: February 18, 2011, 11:51:28 AM »
Titanium would be lighter, I think swell is more concerned about cost.
Offline P_Camps
« Reply #9 on: February 19, 2011, 08:42:52 AM »
a 15 pound frame??  that would be bananas.
CMON SCIENTISTS OF SOHC4 BUILD THY FRAME!! ;D ;) ;D ;)
1978 CB550
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #10 on: February 19, 2011, 08:59:23 AM »
A titanium replica frame would be a noodle.
Ya, titanium is strong and light, but it sure isn't known for it's stiffness.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7k5atg0sfcc5dnbjhprvgfd7a0&/topic,60973.0.html
« Reply #11 on: February 19, 2011, 09:36:03 AM »
why do this to this old bikes..i like them like the are..dinasaures from the 70" dont hurt them.save them
i hate all this v-w.... vords
Offline Tim2005
« Reply #12 on: February 19, 2011, 09:54:16 AM »
You need to find yourself a Seeley frame, it's not far off that at all: "the Seeley frame, complete with rear swingarm only weighs 26.45 lb (12 kg)" from http://www.satanicmechanic.org/seeley.shtml
alocker
« Reply #13 on: February 19, 2011, 10:23:46 AM »
Send your forks, engine, and swingarm to Harris or Spondon and they will probably make you one.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #14 on: February 19, 2011, 10:43:10 AM »
Take a look at Rick Denoon's home built frame, also from Canada, not aluminium but certainly lighter and more modern looking.
http://www.denoonsp.com/
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #15 on: February 19, 2011, 10:55:18 AM »
Damn, didn't know Ti had 1/2 the stiffness of steel. Makes me want to rethink about possibly getting that Mootour bike I have been wanting for a while now.
Offline fatmatt650
  • Part Deux
« Reply #16 on: February 19, 2011, 11:45:29 AM »
Get the Moots! I guarantee you that frame is NOT a noodle. Look at the tube size. 2 tubes of different materials w/ the same dimensions will have different properties. That's why a Ti framed bike (or aluminum) uses fatter diameter tubes w/ thinner wall thickness. The manufacturer tweaks his tubesets to get the desired flex where he wants it.
P.S. Check out the super sexy ti spring. They don't need as many coils to get the same amount of flex as steel because pond for pound, ti is flexier. At least, that's what years of geeking out over mountain bike magazines teaches me.  ;)
« Reply #17 on: February 19, 2011, 02:10:10 PM »
That would be the way to go...... ;)
« Reply #18 on: February 19, 2011, 02:43:03 PM »
Don't forget this is basically what Tintop will do. Recreating a chromoly chassis for a 750 originally done back in the seventies by Denis Curtis cmrracingproducts.com. Denis is still at it & I can tell you he is a craftsman.
I'm sure he would gladly build a frame for anyone here, and then why not an alloy fuel tank to top it off.  ;D
Offline Tintop
« Reply #19 on: February 19, 2011, 04:08:22 PM »
Actually he will be starting on the frame for my 550 racer (& 2nd for a 750) mid March.  Have toyed with the idea of doing the 750 frame in SS.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline socalenduro
« Reply #20 on: February 19, 2011, 05:36:17 PM »
Thats alot of the point of a Ti bicycle...the light amount of flex will bring the frame alive and soften the ride. (if designed correctly) Moots makes some killer bikes. They know how to lay out the frame designs
Aluminum bikes are known for their stiffness, cro-mo is a bit more forgiving, and carbon fiber is just magic (can be ultra stiff or flex depending on how the fibers are laid and set up)
« Reply #21 on: February 19, 2011, 05:50:47 PM »
I've got one, and I'm keeping it!!! ;D
