Author Topic: Trip Reset Thingy?  (Read 8463 times)
Offline krmtrains
Trip Reset Thingy?
« on: February 22, 2011, 06:19:20 AM »
The odometer on my '75 CB550 is missing the knob the resets the trip mileage.  Does anyone know if a replacement is available?  I can reset it with a needle nose pliers, but now that the fairing is back on, that is almost impossible to do.  Maybe someone has made something that works.
Thanks for the help!
Kevin R. Mueller
1975 CB550K
2000 Shadow Aero VT1100 C3 Red/Black
2000 Shadow Aero VT1100 C3 Yellow/Black
Offline mynameismudd
Re: Trip Reset Thingy?
« Reply #1 on: February 22, 2011, 06:43:52 AM »
have you asked over in the wanted section? just a thought ???
nomad
« Reply #2 on: February 22, 2011, 07:14:14 AM »
This?  It's from the speedo of a '74 750.  The white stuff in the grooves looks like old paint.  And the set screw is a tad rusty.  It shouldn't be too hard to clean it up.  If you can verify that it'll fit you can have it.  I would imagine that the 550's and the 750's from those years shared the same gauges (or at least the same basic parts).  PM me your address and I'll try to get it out by the weekend.
Offline krmtrains
« Reply #3 on: February 23, 2011, 03:20:31 AM »
I will give that a try!  If it doesn't fit, I'll pass it along to someone else who might be able to use it.  Thanks!  I sent you a PM.
Kevin R. Mueller
1975 CB550K
Offline IndyFour
« Reply #4 on: February 23, 2011, 05:31:45 AM »
I can confirm that the one pictured above is not the correct one.  I very kind soul here on the forum send me one just like that last week (Thanks again!) and it did not work.  I "re-engineered" it by taking a hacksaw to it and chopping off all but just the end with the set screw and MADE it kind of work, but it's far from perfect.
They are hard to find.  I've been looking for one for a year.  Most used speedometers you find also have them missing as well.   :-\
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
nomad
« Reply #5 on: February 23, 2011, 05:54:08 AM »
Thanks for the heads up.
So, Kevin, do you still want to try it or do you want to keep looking for the right one?  Let me know by Friday morning (when I was going to send it out to you).  You're still welcome to it, I just wasn't sure if you wanted to have to hack it up to make it just kind of work.
Offline apex_seeking
  • Ron Swanson is a
« Reply #6 on: February 23, 2011, 07:19:04 AM »
I have one from a 75 550 and it looks just like that one. It came with the speedo which was in pieces but it looks just like the pic and matches the one currently on my bike. I can send it to you if all other avenues fall through. Just pm me.
Offline octagon
« Reply #7 on: February 23, 2011, 11:57:37 AM »
the trip odometer reset peg on a 123 series mercedes will work - that's late seventies - early eighties 240d's, 300d's, etc. the peg looks good too - german design esthetics etc.
the peg inside diameter is wider than the honda peg, so you have to insert a piece of thin rubber tubing in the peg hole first, then thread it on - speedo stud is left hand thread.
Offline krmtrains
« Reply #8 on: February 23, 2011, 01:11:22 PM »
That's an excellent alternative.  I'll see if this one fits, as there appear to be two sides to that, and let you guys know.  Thanks for the help.
Kevin R. Mueller
1975 CB550K
nomad
« Reply #9 on: February 23, 2011, 02:03:46 PM »
Just so I'm clear, do you mean you'll see if the one I have will fit or are you going to try the other one that octagon suggested?
Offline krmtrains
« Reply #10 on: February 24, 2011, 01:42:16 AM »
I guess I thought I would try yours first.  One says it fits, one says not.  My odometer is not like the one in the picture posted above, I think the reset is on the back. not on the side.
Kevin R. Mueller
1975 CB550K
nomad
« Reply #11 on: February 24, 2011, 02:15:19 AM »
Ok, I'll get it out on tomorrow. :)
Offline Nortstudio
  • Not nearly an
  • Just getting started...
    • MotoPreserve
« Reply #12 on: February 24, 2011, 05:33:05 AM »
Like many people on this site - I bought my bike with this little bugger missing too.  I looked for a bit when i first got it, but then finally gave up.  Seems like they are tough to get ahold of.
I have a quick question: if/when the piece can be found (or donated by very cool forum members), does it work just like putting pliers in there?  I mean, does the special piece offer some other type of access to a mechanism that resets it quicker, or is it always turn, turn, turn???
Thanks,
Scott
1976 CB550K...in progress
1975 CL360...eventually custom
2009 Husqvarna TE610
a blog about wrenching in Brooklyn, NY
“Success is dependent on effort.”
~Sophocles
  • Ron Swanson is a
« Reply #13 on: February 24, 2011, 12:19:58 PM »
Mine, with everything working as it should, is turn, turn, turn.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #14 on: February 24, 2011, 12:57:30 PM »
Drats! That's what I was afraid of.
You know, the look of the German engineered piece above looks like a electrical wire cap. I wonder if I could rig one of those to fit in there? This thread has me thinking all McGuyver....
~Sophocles
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #15 on: February 24, 2011, 03:06:49 PM »
Maybe it's been used on this site before, but I just tried the electrical cap (thing used to screw two wires together) to reset my trip meter. I cut the depth down with a dremel, and it fit right on there and reset it WAY quicker than when I once tried the needle nose on there.
I took it back off and stored it under the seat, but it seemed like it would have stayed on there if I had worked it in a bit more.
Now, once I get this thing chromed, I'll be all set....
~Sophocles
Offline krmtrains
« Reply #16 on: February 24, 2011, 03:40:17 PM »
Now THAT is some creative thinking!
Kevin R. Mueller
1975 CB550K
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #17 on: February 24, 2011, 03:43:04 PM »
Sparked from that photo above, which I now realize is a totally different speedo than mine.  Had I looked closer, I would have never tried it :)
~Sophocles
Offline Gordon
  • 750K1, 550K2
« Reply #18 on: February 24, 2011, 05:20:23 PM »
I was inspired by this thread to finally attempt to do something about the missing trip reset knob on my 550.
I've had a repair kit to replace a table lamp switch in the top drawer of my dresser for several years.  I never really used the lamp much in the first place so never got around to fixing the switch after it broke.  It's the perfect size, and even looks half-way correct as a replacement trip knob.  I reamed out the hole with varying size screwdrivers until it was a snug push fit on the reset shaft, then put a dab of silicone gasket sealer in to keep it from vibrating off.  It works great, so far, and I don't see any reason why it won't stay put.  It doesn't take much torque to turn the trip odometer, so it shouldn't work it's way off when used.  We'll see.
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #19 on: February 24, 2011, 05:25:08 PM »
Gordon, that is perfect!  Now for the chromoly resurfacing, or perhaps carbon fiber, and we are good to go! :)
~Sophocles
Offline Gaither
  • '77 CB550F
« Reply #20 on: February 24, 2011, 09:56:06 PM »
Nort and Gordon get to split the prize!!!! (Nort, you could put a dab of black paint on it.)
This should go in Tricks and Tips. A lot of folks have been looking for those little knobs.
Gaither ('77 CB550F)
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #21 on: February 25, 2011, 06:05:24 AM »
I put it over in the tips and tricks section.  My first entry to that area....what a thrill :)
~Sophocles
Offline Gaither
  • '77 CB550F
« Reply #22 on: February 25, 2011, 02:29:40 PM »
Nort
Be sure to get Gordon's in there too. Both will work well.
It is nice to have choices!
Offline Nortstudio
  • Not nearly an
    • MotoPreserve
« Reply #23 on: February 25, 2011, 05:07:48 PM »
I put both options in there.  Go check it out, Gordon and I are famous! :)
Nort
~Sophocles
Offline Gaither
  • '77 CB550F
« Reply #24 on: February 25, 2011, 06:54:26 PM »
Well, one or you is famous and one is notorious. I'm just not sure which is which!
You both had a good solution to an all too common problem.
