Author Topic: Just Picked up a 1983 CB550 SC  (Read 2460 times)
infowire
« on: February 26, 2011, 04:26:12 PM »
Hello,
First bike and first post here, just wanted to introduce myself.
 I just picked up a 1983 Honda CB550 SC for 950 bucks, it has 23,000 miles. Starts up and sounds good, one of the carbs leaks a bit of fuel not too much tho. Any suggestions where i can get that fixed?
 Another issue is My turn signals do not work as well as low beam. All the bulbs are ok, i have not checked the flasher yet. I know i have seen others having same problems.
« Last Edit: February 26, 2011, 08:33:09 PM by infowire »
Offline dhall57
Re: Just Picked up a 1973 CB550 SC
« Reply #1 on: February 26, 2011, 04:33:00 PM »
550's are great bikes. Lets see some pic. ;D ;D
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Gaither
  • '77 CB550F
« Reply #2 on: February 26, 2011, 05:16:57 PM »
info
Welcome! You have come to the right place. A lot of good, helpful and knowledgeable folks here. Frankly, they have helped me a lot with my 550.
Also, there is a lot of helpful info if you will search any subject/problem.
From what I have learned here, may I make a couple of suggestions? (You likely already know about these things and may have already done 'em.)
1. Clean your fuse clips - a .22 caliber bore brush works perfectly. The clips may just look a bit dull but they should be bright and clean (ask me how I know). Make sure the clips grip the fuses very tightly (may have to carefully squeeze 'em a bit).
2. Run a "Popwood Ground" by splicing into only one of the green wires soldered to the large headlight retaining nuts inside the headlight bucket. Run this new ground wire to a coil mounting bolt using a ring terminal. Clean the frame to bright metal where the ring connector touches the frame. Then, you wont have to hunt and clean each and every ground connection on the bike. This may correct your turn sig/headlight problem - of course, it could be some other problem.
3. Clean ALL "gang" electrical connectors in those poly housings (including the one on the ignition switch) and the pack 'em with dielectric grease (to help prevent more corrosion).
These things fixed my problems (similar to yours). Til I was told on this Forum to do these things, my 550 was absolutely usless!
The wiring on these ol' bikes accumulate lots of corrosion over the years that causes a lot of elecrtical problems. These simple things can prevent a lot of problems for you (if they haven't already been done).
Good luck with your 550.
Gaither
Gaither ('77 CB550F)
Offline fergie
« Reply #3 on: February 26, 2011, 06:33:41 PM »
sc?
The most interesting man in the world
Offline fastbroshi
  • Puppet
« Reply #4 on: February 26, 2011, 08:07:01 PM »
Maybe he meant '83?
Just call me Timmaaaaay!!!
infowire
« Reply #5 on: February 26, 2011, 08:32:50 PM »
Oh yeah i did mean 1983 =) My bad. Yeah i haven't started doing anything on it yet, just wanted to see some suggestions. I will get pics as soon as i take some =)
Offline fergie
Re: Just Picked up a 1983 CB550 SC
« Reply #6 on: February 26, 2011, 09:57:10 PM »
thats a twin cam isnt it?
Offline Roach
« Reply #7 on: February 26, 2011, 10:08:12 PM »
WHAT...They have twin cams now damn... it must get twice the horsepower then right? ;D ;D ;D ;)
1978 CB550K Cafe Racer
infowire
« Reply #8 on: February 26, 2011, 10:18:24 PM »
yeah its dohc =P sorry i know the forums sohc but its still a bike =)
« Reply #9 on: February 26, 2011, 10:41:32 PM »
