shouldn't have more than a 15 psi difference between cyls for a smooth run, but my bet is you've got a dying motor on your hands. have you tried a leak down test? dry then wet? if it leaks down quickly dry, and slowly wet it's a ring sealing problem, if it leaks down fast wet and dry, you're looking at valve work.
