Author Topic: horn issues  (Read 1056 times)
Offline larry
horn issues
« on: February 28, 2011, 05:31:32 PM »
I read about the nonfunctioning horn bathed in boiling water.  And I read about screwing around with the mounting screw.  I am wondering if there is any other options to fix the horn.  If I hooked the leads to a 12volt battery and the horn was good it should sound right?
Offline Gordon
  • 750K1, 550K2
Re: horn issues
« Reply #1 on: February 28, 2011, 05:35:27 PM »
Not the mounting screw.  There should be a small diaphragm adjusting screw on the back of the horn.  Sometimes if you fiddle with that it can bring life back to a dead horn.  And yes, if the horn is good it will sound when you hook it directly to the battery.
If you end up needing a new horn, may I suggest the dual-note Freeway Blasters by Fiamm.  I have them on both my bikes and they sound like a big pick-up.  Really wakes people up!
Offline DarcyCB400F
Re: horn issues
« Reply #2 on: February 28, 2011, 07:20:56 PM »
Hi Larry,
I am the guy that boiled my horn...
Here's what I have learned about horns;
Inside a horn there is a small electro magnet that when electricity is provided, it pulses and while it is pulsing it pulls a metallic strip that causes a vibration which in turns causes the horn to work.
Now that may not be entirely accurate but it is at least a general working description. Other forum members may elaborate if they wish...
My horn didn't show any sign of life if provided electricity from the bike's power or battery charger hooked to the horn leads. Once I boiled it, I was able to get it to "react" when I hooked it to a battery charger; it would spark, "jump" and make a "CLICK" but did not sound like a horn. Because my horn is mounted to the bike by a large set screw (10 mm? with a nut 12 mm? which was removed at this time) I then mounted the bracket to the horn as per design using the set screw and nut then held it in my hand. I didn't mount the bracket on the bike so I could adjust it. Hooking the horn up to the leads on the bike now gave me an opportunity to tune the horn. It helped to have someone work the horn button while I did this as my hands were busy holding/tuning the horn.
There is a flat blade screw driver slot in it for the porpose of tuning. The mounting set screw is used to tune to the horn to a point where I could get it to "sound" to a point but didn't work 100% but was close... say 90%. Then I used the very small tuning screw to finely tune the horn to perfection. The tuning screw would be about 4mm with a tiny lock nut. By turning this screw in or out, I was able to get the horn to work like it was brand new.
One word of caution... the use of ear plugs is recommended!!!  ;D
« Last Edit: February 28, 2011, 07:58:07 PM by DarcyCB400F »
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
Offline Deltarider
Re: horn issues
« Reply #3 on: March 01, 2011, 01:38:23 PM »
Or do what I did years ago and mount a pair of Voxbell horns. Great sound and loud. Closest you can get to a set of five-chimes. ;D
« Last Edit: March 01, 2011, 01:44:30 PM by Deltarider »
CB500K2-ED Excel black
Offline larry
Re: horn issues
« Reply #4 on: March 01, 2011, 02:02:05 PM »
Hey, an update.  I blew it out.  banged on it.  Checked for continuity on the button and horn.  Hooked it up to a battery.  Screwed both screws in and out checking to see if it would work every time I moved either screw.  No guts no glory.  I'm gonna boil it according to the above recipe.  Let you all know how it works out after I deal with my leaky carb problem and glass beading my tank.
bollingball
Re: horn issues
« Reply #5 on: March 01, 2011, 02:20:21 PM »
FreeWay Blasters and Voxbells ? I need a new horn I wish I could hear them. The power usage does not matter you do not use them that long but I would or have relayed mine (stock) out. Can both of you post a site so I can buy one or two?
Offline Gaither
  • '77 CB550F
Re: horn issues
« Reply #6 on: March 01, 2011, 02:31:19 PM »
When I got the 550 the horn was silent. I didn't even argue with it. I always felt like these "skeeet" sounding horns were an open invitation to get someone to run over me (us). IMHO, they sound like a small, cheep, older, foreign car horn.
A fellow gave me a horn. 'Have no idea of it's origin (wish I did). It went on the orig bracket. Man, is it LOUD! Makes a big, loud "booop" that can be heard. I figure the orig horn being shot was a blessing. I might have been tempted to use it.
IMHO, get a LOUD horn and use it at the slightest indication of need. Who cares if "they" don't like it - just as long as they hear/see you. Lay that orig on the shelf and put it back on the bike if/when you sell it.
To each his own.
Gaither ('77 CB550F)
bollingball
Re: horn issues
« Reply #7 on: March 01, 2011, 02:46:31 PM »
Ten four Gaither I have a cheat autozone now but it should be LOUDER
