Author Topic: Where Does This Missing Part Go?  (Read 1043 times)
Offline RSchaefer
« on: March 01, 2011, 08:33:51 AM »
The motor is out and most everything removed.  I was yesterday doing the final strip down to the frame.  I removed the front wheel and brake, triple clamp, rear wheel and brake, side stand, center stand & swingarm.  Probably after I removed the rear wheel I laid it over on its side to get to the stands and swingarm.  After getting everything off, uprighting the frame and putting away the tools I find this part.  Not the center stand pivot axle, but the small bushing!
For the life of me I cannot seemed to figure out where it came from.  I have been taking pictures of the tear-down and bagging everything in labeled freezer bags.
Anybody recognize this part?
Thanks!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Where Does This Missing Part Go?
« Reply #1 on: March 01, 2011, 08:53:47 AM »
Looks like the steel dowel insert that is used in some of the rubber grommets. I believe the grommets for the battery tray have these steel inserts as well as the grommets for the guage (tach/speedo) mounts, the rear fender grommets (I think) as well as various other grommets. The parts fiche may show some of these.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #2 on: March 01, 2011, 08:54:13 AM »
Hmm looks pretty small but some good detectives around here. You didn't mention the bikes model,is it a 750??
« Reply #3 on: March 01, 2011, 08:58:00 AM »
Oh yeah, the tail light mounting grommets have these as well (I had my tail light off this weekend) where the light mounts to it's bracket.
« Last Edit: March 01, 2011, 09:01:32 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline RSchaefer
« Reply #4 on: March 01, 2011, 09:07:28 AM »
Oh sorry, its a '75, 750F.  I took the tail light rear fender assembly off probably a month ago so I would not think it was from that.  Maybe it lodged somewhere in the frame based on earlier parts removal and fell out/off when I turned the frame on its side?  I really took allot of care removing each part, looking and photographic each connection, etc.  I just cannot figure out where this little bushing goes.  Looks really clean so it wasn't exposed to the exterior!
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #5 on: March 01, 2011, 09:11:05 AM »
For some reason I am getting a rear disc brake caliper area vibe or maybe to much coffee  :D   Edit----I see a part #28 on the Cyclepartsnation fiche but it won't let me post a pic ??? Here is a pic from my home made parts book.
« Last Edit: March 01, 2011, 09:29:35 AM by ekpent »
Offline faux fiddy
  • bike in a box
« Reply #6 on: March 01, 2011, 11:10:40 AM »
Most rubber parts with a round hole through them have this inside. Battery box and fender grommets.
« Last Edit: March 01, 2011, 11:12:34 AM by tree fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline RSchaefer
« Reply #7 on: March 01, 2011, 02:18:53 PM »
Congrats!  You guys are great!!
It turns out it was the rear brake, but not at the rear brake body connection, but at the swingarm connection!!
Thanks you, thank you, thank you!!!
Rear brake arm, one side to brake, one side to swingarm
Bushing goes at end of bracket and yes there is one just like it at the brake body end
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline RSchaefer
« Reply #8 on: March 01, 2011, 02:19:50 PM »
Thanks ekbent!
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
