Author Topic: neutral light not lighting  (Read 4039 times)
Offline rab1dwolf
« on: April 02, 2006, 11:49:39 PM »
ok I tore into my electric system (1982 cb650sc) and got my headlight working (cleaned thumb switch) but my neutral light is still not funcitoning
here are the symptoms and what i have found so far.  The light did work and had recently gone out when my headlight did. I took apart the instrument cluster and exchanged the light bulb and cleaned everything out and had the bike in neutral as well.
the socket is getting the full 12volts (tested with a meter) so I beleive the switch is fine still.
All wire connections seemed to look good. all other indicator lights work fine.
I think the problem might be with the ground wire from the socket (green/red i belive) but I'm not sure.
Also the clutch saftey switch on my bike is unhooked and the wires for it twisted together (so the bike will still start). and it appears there is a ground wire not connected to anything in the read of the bike near the regulator/rectify thingy(dont think that this is related though)
any suggestions/help would be good.  I tried browsing the forums and didn't find too much relating to this
edit: just looked at the wiring diagram and it seems the grren/red goes directly to the switch? if that is the case then that means the the switch is grounding the light when in neutral thus lighting it correct? so maybe it is the switch....anyone know where that can be located at?
« Last Edit: April 02, 2006, 11:54:07 PM by rab1dwolf »
1982 cb650sc nighthawk.  the work never stops.
Offline KB02
Re: neutral light not lighting
« Reply #1 on: April 03, 2006, 06:45:36 AM »
Do you mean the switch itself on the bike, or the switch itself as a part to purchase?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline byidesign
« Reply #2 on: April 03, 2006, 07:49:19 AM »
the switch{neutral } mounted on the engine case is a grounding type switch
    that makes the indicator light come on. you can put a meter on it and
     shift in and out of gear to test .{no change ,replacement time} you should get a wiring diagram{see FAQ"S pages}and a
      {manual} for it . for the wire color coding/routings , then remedy whomever played
       with the wiring before you got it.{much better than just trying things.}
           Hope it Helps
                  Bruce
82CB650SC,80CM400
Williamsd
« Reply #3 on: April 03, 2006, 08:33:25 AM »
I had a neutral switch problem on my 82 CB650SC  (same bike).  It turned out to be the switch under the chain cover (#10 in diagram).
The contact has a sandwich of an isulating material between brass plates, with a rivet in the middle which makes the contact.   My guess is the rivet corroded and so contact was lost.  As a short term fix I soldered a wire between the plates.
Offline rab1dwolf
« Reply #4 on: April 03, 2006, 10:38:18 AM »
cool I'll take a look at it today.
The thing worked fine before I started monkeying with the cluth basket on the right side of the bike.  I'm hoping this is something small I can just quick fix for now and get a replacement later.
Offline rab1dwolf
« Reply #5 on: April 03, 2006, 06:38:02 PM »
update: something apparently has eaten the wire going to the switch down by the shifter....go figure
I'll have to splice in a new wire at some point i suppose...
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #6 on: April 03, 2006, 08:52:53 PM »
I have a similar issue except in my case the light comes on in second gear and neutral.
I think the shifter drum is not indiceing quite right.
Oh well, another problem to fix.  ::)
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline rab1dwolf
« Reply #7 on: April 04, 2006, 09:07:22 PM »
is it sad that i like working on this bike as much as riding it?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: April 05, 2006, 02:37:09 AM »
No, I don't think so anyway.  ;)
Offline KB02
« Reply #9 on: April 05, 2006, 05:19:01 AM »
How do you properly test the neutral switch? Can you still do it while it is installed in the bike?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #10 on: April 05, 2006, 02:33:36 PM »
I was hoping for a answer here as well.
I have power at the bulb, but no ground so light does not work.
When I shif into another gear I still have power at the bulb, still no ground?
Is the problem in the headlight housing somewhere?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #11 on: April 05, 2006, 02:42:41 PM »
HA!  I am a GOD!
RED/WHITE wires disconnected in the headlight bucket. Same as the 1st post, I was dicking around in the bucket one day when my headlight went out. (Bad ground there as well).
