Spanner that's about the time I was fixing TV's, ah tubes, I remember if you got to close to the regulator it would burn a hole in and out, little black dot in your hand never did find the out and the high voltage would zap you like a lightning strike, ah the good old days then Zenith introduced a new model with transistors and the fun began, occasionally the regulator circuit would fail in a certain way and high voltage would go past normal 27.5 KV to around 54+ Kilo Volts at which point it would arc through the picture tube, pop it and come to a smoking stop, one of our customers had it happen to him and his family, said it was impressive as hell all of a sudden the picture got really bright the was a loud pop and fire, smoke blew the breaker etc he was pissed, got watch his new TV for a couple of hours and had to fight with Zenith for a replacement.
Bill the demon.
