Author Topic: CB550F , four 6mm threaded studs under breather cover.  (Read 1093 times)
Offline kendo57
« on: March 04, 2011, 07:34:54 AM »
i removed the breather cover from the top of the cam cover and there
are four 6mm studs under there doing nothing. I cannot see anything on
a micro fiche so wondered what they are for.
Any ideas?
Offline Deltarider
Re: CB550F , four 6mm threaded studs under breather cover.
« Reply #1 on: March 04, 2011, 08:14:11 AM »
Forget the microfiche and start with the right parts list. I bet yours has the modified cylinder head cover or maybe some PO modified himself.
« Last Edit: March 04, 2011, 08:23:57 AM by Deltarider »
CB500K2-ED Excel black
Offline lone*X
« Reply #2 on: March 04, 2011, 08:18:26 AM »
Didn't the modified cover become standard sometime in 76 for all 550's?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Deltarider
« Reply #3 on: March 04, 2011, 08:22:38 AM »
That's why I referred to the right parts list.
Some owners that had the old model modified the cover themselves.
Offline geminimotors
« Reply #4 on: March 04, 2011, 05:01:00 PM »
So what are those studs? I was sorting through my boneyard and I noticed them also.
Offline luap
  • LAWL
« Reply #5 on: March 04, 2011, 05:03:39 PM »
the studs are to hold the rocker arms in depending on what year 550 it is
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline TIM TINGEY, age 55
  • Service manager Matts Vintage Motorcycles
  • 916 208 0935
« Reply #6 on: March 04, 2011, 10:59:02 PM »
71 thru 73 CB500 FOURS had long rocker arm shafts-one shaft for each side of engine intakes and exhaust valves. When Honda introduced the 550 they went to short rocker shafts that had less support/engagement and tended to rotate in ther'ye journals causing pre-mature wear and rockers becomming seriously misalighned with the valves. By 76' Honda introduced the updated cam cover with the studs you mentioned holding each rocker shaft in place so they cannot rotate.
Offline Deltarider
« Reply #7 on: March 04, 2011, 11:59:36 PM »
Actually it was the other way around: the shorter rocker shafts (8x) caused problems and were substituted by longer rocker shafts (4x). The rocker arms themselves were not modified. As always, have a look in the parts list and it will be clear.
« Last Edit: March 05, 2011, 12:23:24 AM by Deltarider »
Offline kendo57
« Reply #8 on: March 05, 2011, 02:02:17 AM »
Thanks, i can put them studs out of my mind now and get on with the rebuild.
