Author Topic: printer no talky to computer  (Read 1785 times)
Offline tramp
« on: March 06, 2011, 08:53:14 AM »
says usb port not recognized
when i go to control panel it says printer is off line
any usb port i plug it into says the same thing
uninstalled hp software then reinstalled
same problem
now what?
1974 750k
Offline 78 k550
Re: printer no talky to computer
« Reply #1 on: March 06, 2011, 09:08:01 AM »
virus scan.
if you plug in a mobile memory stick will it see it?
I should of read your complete post.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline tramp
« Reply #2 on: March 06, 2011, 09:18:37 AM »
already virus scanned
i really think the drivers on the computer are messd up
1974 750k
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: March 06, 2011, 09:22:36 AM »
What OS are you running? Will it allow you to "roll back" to a previous checkpoint? Have you tried rebooting?
Offline Kframe
  • Life is good!
« Reply #4 on: March 06, 2011, 09:26:04 AM »
Did it work before and now it doesn't, or is this a new printer to this computer?
If it used to work, what did you change?  (Installed updates, added/removed a program, etc?)
Try a different cable and port just to eliminate those variables.
Could try rolling back to a restore point.
In device manager for the driver, see if there is an option to go back to previous version; I've had a printer that worked but when driver updated it 'lost' it.  When I rolled back to previous driver it 'found' it again.
Man, these computer issues can be SO frustrating!
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline tramp
« Reply #5 on: March 06, 2011, 09:39:17 AM »
had the printer hooked up before
disconnected it for about a month
bought new ink i needed
and now it won't talk to computer
computer says it is offline even though it is turned on
1974 750k
Offline 333
  • Time for change
« Reply #6 on: March 06, 2011, 10:41:48 AM »
If running Windows, try this;
Leave printer hooked up.  Run Windows Update.  Don't use "Express(Recommended)",use the "Custom" button.  When it get to where it says how many "Important" updates are needed, look to the left and select "Hardware".  If running Vista or 7, navigate to the "Optional" settings.  See if your printer driver is listed.  Select it if there.
What may have happened is that your computer "forgot", and the driver that came with the printer is no longer good enough.  It's worth a try.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline tramp
« Reply #7 on: March 06, 2011, 11:22:50 AM »
just tried that
nogo
1974 750k
Offline 333
  • Time for change
« Reply #8 on: March 06, 2011, 12:33:30 PM »
Have you tried a different USB cable?  They do go bad sometimes.
If we are to think of this as a software issue, we need to know what Windows you are using.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #9 on: March 06, 2011, 12:40:01 PM »
I'm going to guess Windows XP. From the Start menu open up "Printers and Faxes", right click on the printer in question, select the option "Use Printer Online". Sounds like it is currently set to "Use Offline" so simply change this setting via the right click option menu.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline faux fiddy
  • bike in a box
« Reply #10 on: March 06, 2011, 12:43:20 PM »
Go to HP or other software site to see if you can update the driver or install a new one.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
« Reply #11 on: March 06, 2011, 12:50:17 PM »
Most computer problems are between the keyboard and the chair... ;)
TAMTF...
Wilbur
Projects:
Offline 333
  • Time for change
« Reply #12 on: March 06, 2011, 03:50:58 PM »
Operator headspace error?
Offline tramp
« Reply #13 on: March 06, 2011, 03:51:44 PM »
i will try to change to on line status tomorrow
i got a new driver update today from hp
no help
and yes i hate computers and they hate me back
1974 750k
Offline tramp
« Reply #14 on: March 06, 2011, 03:56:29 PM »
i just swiched it to online
the computer says it does not recognize the device
1974 750k
Offline cookindaddy
  • I sure love this bike!
« Reply #15 on: March 06, 2011, 04:12:58 PM »
Is it possible that the printer has gone bad?
Try it on another computer?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #16 on: March 06, 2011, 04:17:56 PM »
Some HP printers are kind of fussy. Disconnect and uninstall the printer. Reboot, run the updated printer install you downloaded from HP, do not connect the printer until prompted to do so by the installation routine. Some HP printers don't install properly if you connect them before running the install routine. Good luck (damn computers..) >:(
TAMTF...
Wilbur
Projects:
nomad
« Reply #17 on: March 06, 2011, 05:09:59 PM »
Buy a Mac.  ;D
Offline Anti-Johnny
  • 75 cb750k
  • Poser
« Reply #18 on: March 06, 2011, 05:14:34 PM »
i work for a tech support company. sounds like a driver issue with your usb port. and if its an older computer, and maybe newer, take a look in the usb port to see if anything has snapped or wiggled loose. and hp printers are notoriously bad. the cheaper ones are made in a different place than the more expensive ones. quality is all over the board.
music
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #19 on: March 06, 2011, 05:28:51 PM »
USB issue on the PC is my guess.
Need OS and service pack.
Printer model.
Many have suggested doing a system restore back to when you last had the printer working.
Have you tried this? Do you need instructions on how to do it?
We'll get you through this.
BTW I work tech support also and have only seen this on HP home printers. Usually the All in one printer/scanner/copier models
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline DavePhipps
« Reply #20 on: March 06, 2011, 07:55:43 PM »
Go to start menu and click run. In the run box type services.msc
This will bring up a listing of all the services running on your computer.
Scroll down and locate the print spooler - right click & select restart.
This sometimes works.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline tramp
« Reply #21 on: March 07, 2011, 01:40:36 PM »
tried that
says document is in hold
1974 750k
Offline DavePhipps
« Reply #22 on: March 07, 2011, 01:57:46 PM »
Are there any documents in the queu? If so, delete them and restart spool.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline cookindaddy
« Reply #23 on: March 07, 2011, 03:47:04 PM »
Do you know that the printer is working? Try it on another computer? You don't need to install the drivers but if you just plug it in and power it on and Windows recognizes that something has been plugged in, that would be a good sign. If no signs of life on another computer, your printer is dead. I think you said it sat for a month?
« Reply #24 on: March 07, 2011, 03:53:12 PM »
On the computer i just replaced the USB ports all slowly died, not too sure why but one by one they failed.Try plugging a USB stick or something else in the port and see if it is working, if it is I would delete all printer info on your computer and do a reinstall with new drivers, make sure you have the current service pack on your system...
