Author Topic: Flasher Relay Location  (Read 2591 times)
klroywshere
« on: April 30, 2005, 10:53:41 PM »
Where is the Flasher Relay located on a 81 Honda cb650c???
Offline Dennis
Re: Flasher Relay Location
« Reply #1 on: April 30, 2005, 11:13:24 PM »
Don't know for sure, but I am familiar with the 500/550 and 750's where they are under the left side cover. That's where I'd look first or check the service manual if you have one.
klroywshere
« Reply #2 on: May 01, 2005, 05:12:55 PM »
Thanks will check I have a clymer manual ordered but was just a little ancious to get working on the bike
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #3 on: May 01, 2005, 05:24:38 PM »
Here is the wiring diagram for your bike - should suggest where the relay is (left side).
Some info is available at www.honda4fun.com - your owners manual is available there.
Also http://www.geocities.com/jbronsky1/cycleshonda.html  seems to be a good read for your bike (and is where I found the wiring diagram)
CHUNG
« Reply #4 on: May 01, 2005, 06:16:14 PM »
It'll be a little square cube. But it could be shaped like a beer can. Ahhhhhhhhhh beer ;)
I think it's under the fuel tank on that bike beside the IGN coils. Otherwise they are usually located of the left side under the bodywork.
Offline Zeke
« Reply #5 on: May 02, 2005, 07:08:27 AM »
My 80 650c has the relay between the battery and rear tire.  It's mounted on a small angle bracket.  I had to remove the front plastic half of the fender to get to it.
PITA to get to.
klroywshere
« Reply #6 on: May 03, 2005, 10:58:32 PM »
 ;D  Just thought I would let you guys know that the reason I couldn't find the Flasher Relay is because there wasn't one  LOL
I found where it was supposed to be  under the rear finder.  I went down and bought a Flasher for a 1977 Honda accord and put it on and TAdaaa  I now have signals.  Thanks for all your help.
Offline Paul
« Reply #7 on: May 04, 2005, 01:26:16 AM »
I was just going to say..Whatever you do , don't get a genuine one, I've seen quotes for about £40 for a "HONDA" flasher relay ! when they can be got for about £3 in any accessory shop.(not handbags) ;D
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
