Author Topic: O-ring chain on 400F?  (Read 1423 times)
Offline TRPLE
« on: April 04, 2006, 09:44:17 AM »
I read some old posts on this last night, but I couldn't find a concrete statement about the 400F.  Is it possible to run a 530 O-ring chain on stock sprockets on a stock 400F?  I read for sure this is not OK on a 500/550.
 - Matt
'76 Honda CB400F
'72 Yamaha CS5
'09 Guzzi Griso 8v
supersport_CB400F
Re: O-ring chain on 400F?
« Reply #1 on: April 04, 2006, 09:54:59 AM »
It will only leave 0.5mm clearence to the case's, I use 530 HD and stay on the safe side  ;D
clzay
« Reply #2 on: April 04, 2006, 10:36:06 AM »
yeah the guy at my local Honda dealer just sold me a RX-Ring chain (530XSO) for my 78 CB550, and I don't even know if its going to fit? Its pretty fat, some people say it will some say it won't? I guess i'll just have to try it.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #3 on: April 04, 2006, 12:40:13 PM »
I use an o-ring 520 chain and sprockets on my 400's with no problems.
Kevin.
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
supersport_CB400F
« Reply #4 on: April 04, 2006, 01:29:13 PM »
Kevin.
I'd use one of those chains/sprokets Kev with no worries, but I have a length of Renolds 530 HD chain.
« Reply #5 on: April 04, 2006, 06:06:40 PM »
I installed a 530 o-ring on my wifes 400 without problem. Next time though I'll switch to a 520, that is if she ever wears this sucker out!
Offline TRPLE
« Reply #6 on: April 04, 2006, 06:55:06 PM »
So when you get a 520 sprocket, how do you know it will fit the 400?  Do you happen to have a known source of 520 sprockets that worked on your bike?  I'd love to downsize the chain and upgrade to a O-ring if I can.
 - Matt
'76 Honda CB400F
'72 Yamaha CS5
'09 Guzzi Griso 8v
Offline ttr400
« Reply #7 on: April 05, 2006, 10:38:21 AM »
In South Africa 520 rear sprockets are not available for the 400,so I buy renthal blanks and machine the centre to fit the 400 hub.
Also need to space out slightly as it's thinner than the oe sprocket. the front sprocket lines up as per oe,as it has a boss to keep it in the same line.
You can order front and rear sprockets from sprocket specialists in the USA, they will make up a rear for you, the front is a stock item I think from the SL350 twin.  I heard that Rick Denoon was going to make up some complete 520 kits for the 400 Four, I think he is a member here.
Where are you Rick?
Kevin.
www.ttr400.com
