Author Topic: rear shock?  (Read 879 times)
Offline shouse76cb
rear shock?
« on: March 10, 2011, 01:56:06 PM »
hello, could anyone tell me if the shocks off an '80 cb750f can be disassembled relatively easy? i found a pair cheap but they need to be cleaned up/coated. thanks for any help
Offline gerhed
Re: rear shock?
« Reply #1 on: March 11, 2011, 07:57:00 AM »
Most shocks will come apart fairly easily but you need to compress them--then unscrew the thing.
Be careful--if your compression technique is a little sketchy and they uncompress at the wrong time--bad things can happen.
          83 XL600R in CB360 Frame
Offline jaguar
Re: rear shock?
« Reply #2 on: March 16, 2011, 11:13:42 AM »
you mean to take them apart and rebuild them?
i think someone found a way to rebuild the remote res ones from the DOHC but it was alot of work
