Author Topic: Emgo Air pods for CB550  (Read 2157 times)
Offline Jaimef
« on: March 10, 2011, 02:53:14 pm »
Hello
I'm just finishing my CB550f and after rejetting I've purchased a set of 39mm Emgo air pods, the 2 in the center fit just fine but the 2 on the ends are too big and are pressed against the frame of the bike.
Does Emgo make a smaller filter that has a 39mm flange fit?
What other pods could I put on my bike?
What's the meaning of life?
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Emgo Air pods for CB550
« Reply #1 on: March 10, 2011, 03:04:01 pm »
They don't fit. Unipod foam filters fit. So does the stock airbox  ;)
No.
Offline Queeg
  • insane fuel junkie
  • OY! with the poodles allready!
    • Queegs Problems
« Reply #2 on: March 10, 2011, 03:05:58 pm »
Never jad emgo pods but my uni pods due the same thing. The uni are foam so they just squish a little bit. Unless its gonna crack the rubber or seperate the element from the rubber base.
Did you get the cones ones?
guess who?
Offline Jaimef
« Reply #3 on: March 10, 2011, 03:11:07 pm »
I got the cones allright...
thanks for the advise.
Offline domer
« Reply #4 on: March 10, 2011, 03:26:07 pm »
i might catch heat for this, but i took 2 filters, some good tin snips and cut about a 1/2" off the top. cleaned all the excess out of the cap, filled it with epoxy and stuck it back on. i did not feel any difference, but from what i understand this could mess with the flow characteristics even more than the pods themselves. but again, my bike seems to run fine...
Offline cobrajunkie
Offline cobrajunkie
« Reply #6 on: March 11, 2011, 08:02:03 am »
I just ordered 4 pods for my F1 from Dynoman and received 2 pods that were 3.25" and two that were 3.5" high.  Now they say they are out of stock for another 30 days.  You don't think they were trying to unload the last of two pods as a set of four, do you? knaw.
Offline crazypj
  • I'm brill, me
« Reply #7 on: March 11, 2011, 08:54:20 am »
You can get K&N that fit properly, shorter filters, 'fun' to jet
Offline luap
  • LAWL
« Reply #8 on: March 11, 2011, 08:47:44 pm »
550 should take 35mm  an from tip of cone to tip of rubber booty should measure 2 1/2 in so they dont rub on frame, find those ones a smashed outer pod filter looks like crap, pk22's for uni puck filters an find the shortest in legnth
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline rangelov
  • The Dual Disc Conversion Speedometer Driver
« Reply #9 on: March 11, 2011, 09:21:33 pm »
Don't try to make the Emgos fit.  They are cheap and will separate behind the mounting flange.  They will spin and be loose on the maifold part of the filter.
Don't ask me how I know.
« Last Edit: March 12, 2011, 01:53:02 pm by rangelov »
http://forums.sohc4.net/index.php?topic=76835
CB750K4, Boss maroon metallic, 836cc, RC Engrg 4 into 1, Forks by Frank, air assisted front forks,  JC Whitney 16" rear.
