Author Topic: Main jet clarification  (Read 1708 times)
Offline ddanz27
  • 1974 CB350F
« on: March 11, 2011, 06:47:53 am »
Am I correct in assuming that the larger the main jets are the higher the fuel consumption will be?
Also, when you replace the main jets (to compensate for exhaust or filter changes) do you need to replace the slower jets as well?
1974 Honda CB350F
Offline Shoeboxjoe
  • Large Breasts
Re: Main jet clarification
« Reply #1 on: March 11, 2011, 06:58:49 am »
Yes when running more air you'll need more gas which means less mpg to some extent. There's a pretty extensive Carb section in the FAQ forum that would help. Main jet is only going to help with 3/4 - WOT. You'll probably need additional carb tuning like adjusting needle position, air screw, and yes possibly changing the slow jets.
1977 Honda CB750K Project IDK yet
http://forums.sohc4.net/index.php?topic=121669.0
SOLD 1976 Honda CB750K Cafe project
http://forums.sohc4.net/index.php?topic=52576.0
1964 Honda Trail 55 (C105T) Custom project
http://forums.sohc4.net/index.php?topic=64962.0
1967 Norton P11 (restoring for father-in-law)
1978 Ford Fiesta (at body shop!)
Offline Kong
« Reply #2 on: March 11, 2011, 07:29:29 am »
While intuitively it might seem like larger jets lead to higher fuel consumption like many things intuitive it may not be so.  The key to jetting is not so much to find the largest jet that will work properly,  its to find the jet that will work properly.  In fact a properly jetted engine will run more efficiently than an improperly jetted on and the more efficient the engine is running the better fuel economy it will get.  So its actually quite possible that in the process of taking a lean running (inefficient) engine to a condition where the optimal fuel/air ratio (efficient) condition exists may very well increase your fuel economy.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Shoeboxjoe
  • Large Breasts
« Reply #3 on: March 11, 2011, 08:00:15 am »
I agree with you Kong but in this context I believe he's talking about attempting to increase performance with new exhaust/air filters which is going to decrease fuel efficiency when properly tuned. I don't think it would be a significant decrease however and nothing to be concerned with.
Offline Kong
« Reply #4 on: March 11, 2011, 08:16:48 am »
True that!
1978 Honda CB550K
1977 Honda CB550K
Offline crazypj
  • I'm brill, me
« Reply #5 on: March 11, 2011, 08:53:10 am »
On 1977 CB550F1, stock, minimum 23mpg, best, 38mpg
modified CB550 (591cc, cam, exhaust, electronic ignition)
20+mph faster, 18mpg better at similar speeds to stock bike (110+mph, 39~41mpg)
« Reply #6 on: March 11, 2011, 09:40:01 am »
No.   But, you are considering only part of the equation.
Jet flow is determined by pressure differential across it, inlet to outlet.  It doesn't flow anything if the pressure at each end is the same, such as when the engine is stopped.
A larger jet will flow more volume than a smaller one, given the same pressure differential across it.  Assuming engine demand remains the same, a different air filter design may, by it's nature, reduce the carb throat pressure.  This would require a larger jet size to compensate for the pressure loss in the carb throat.  The common reaction to filter design changes is to make the fuel orifices too big, which allows the engine to run acceptably but will give horrible fuel economy.
That depends on the how much the carb throat pressures have changed from what the carbs were originally tuned to compensate for.  And how much the exhaust has changed the scavenging of the cylinder.
Offline motorhead55
« Reply #7 on: March 11, 2011, 10:07:33 am »
I agree with Kong. When you get an engine tuned and jetted right AND producing more HP. In NORMAL driving mode, you will often see better fuel economy.
Here is a PERSONAL example. I had a 1977 Ford 3/4 ton Econoline van. It had a small block 351 engine in it. The fuel mileage was about 10mpg. It felt lean in running and had low power. Mind you it was STOCK and STOCK jetted. I opened up the mains on it and my mileage jumped to 13-14 mpg. It also had better power. It also smogged well after the jet resizing.
1976 Honda 550F bought new in 1978
2006 Yamaha TW200 TrailWay
1967 Triumph 200cc Tiger Cub
2007 Dodge 5.9 Cummins Diesel, 6spd. Stick, 4X4
1955 European Spec VW Bug, 1700cc engine, Porsche 356 "A" brakes
1939 Willys Pickup
2003 Kubota B7400
