Author Topic: Crankcase compatability question  (Read 590 times)
Offline Eydugstr
« on: March 12, 2011, 12:33:07 pm »
Will I be able to swap the innards of a K2 (engine # cb750e-202903) into a crankcase with the engine #cb750e-2360070?  Any help or links would be appreciated.
Offline wrenchmuch
Re: Crankcase compatability question
« Reply #1 on: March 12, 2011, 01:19:22 pm »
You might have a single row output shaft bearing in the earlier engine while the later one will be a double row bearing . You will need to use the double row shaft assembly in the later cases . The later case is a K4 . Crank main bearings will need to be fitted for the new case . Everything else should just swap over .
Hope this helps
Mike
CB750K1
CB750K4
Offline Eydugstr
« Reply #2 on: March 12, 2011, 01:44:50 pm »
TY.  Yes this does help - Thanks!
