Author Topic: CB400F Carburetor Choke Linkage Spring And Ball Bearing Size  (Read 3971 times)
Offline RickB
    • Pop Magazine
« on: March 13, 2011, 06:26:09 AM »
Hi guys,
So I've been battling to replace the choke locking spring and ball bearing for the carburetors. It's a ball bearing that sits in the end of a spring (like on the kick starter) that is pressed into a hole in choke linkage arm to hold the choke off.
The spring and ball bearing circled below aren't listed in the part fiche, so I don't know their sizes. I've been guessing but it's not going well. I found that the spring from a Bic four-pen is kinda' right and a 3.5mm bearing sort of works, but it's not great. Does anyone know these sizes, know where to get them or have these parts?
Thanks,
Rick.
Offline grant301277
Re: CB400F Carburetor Choke Linkage Spring And Ball Bearing Size
« Reply #1 on: March 13, 2011, 11:35:30 AM »
hey mate not sure if it would be the same but i have robbed one out of a broken kill switch ( honda off,on,off style ) for the choke linkage on a set of mikuni carbs .maybe the same size ??
Offline -CB-Jamie-
« Reply #2 on: March 13, 2011, 03:27:52 PM »
Rick, just measured the ball bearing in a spare set of carbs i have and it's 4mm, so that 3.5mm one you have is pretty close. The 3.5mm bearing should work ok, maybe the spring from the pen isn't strong enough??
Jamie
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline RickB
    • Pop Magazine
« Reply #3 on: March 13, 2011, 04:42:02 PM »
Thanks guys.
Jamie, that is great you were able to measure the stock bearing. Thank you. You don't have a stock spring to measure do you? The width, length and your estimate on strength I guess. That is the hard part to find actually. The spring I'm using is no way near stiff enough I think.
Thanks again guy,
Rick.
Offline -CB-Jamie-
« Reply #4 on: March 14, 2011, 01:35:49 AM »
Ya I just measured it there and it's 7mm long by 3mm thick and actually quite strong for the size of it. It's nearly a struggle to push the spring together between your thumb and finger. Hope this helps
72 CB350/4
77 cb200
09 cbf600
Offline RickB
    • Pop Magazine
« Reply #5 on: March 14, 2011, 06:36:31 AM »
Jamie,
You are a life saver, thanks mate!
Now I have to find somewhere that sells such a small spring. A hobby shop or somewhere that sells remote control cars I think.
Rick.
« Last Edit: March 14, 2011, 06:39:34 AM by RickB »
