Author Topic: 1977 CB750F - Carb Rebuild Help  (Read 3333 times)
absnaqvi
« on: March 13, 2011, 10:02:06 AM »
Hey guys, new to the forum here and was looking for some help.
I read somewhere that the 750F carbs have felt rings for the throttle and choke rails and i dont think i can see any on mine. the reason probably is that i didnt look close enough before i started cleaning the carbs with carb cleaner stuff.
I had tried to take as many photos for the rebuild prior to breaking them apart for cleaning but seems like i didnt take enough. I cant figure out how to put the throttle rails back on the carbs. Any way someone could either point me to a carb rebuild walktrhough or post some pictures? With the riding season coming close here in Iowa, i really would appreciate any help you guys could provide.
I did try to search the forums but couldnt find any good pictures for reference. Looking forward to hearing from you guys. Thanks!
Offline maxspeed140
Re: 1977 CB750F - Carb Rebuild Help
« Reply #1 on: March 13, 2011, 07:36:57 PM »
Rebuilt mine on my 77 750F last summer. Not sure exactly what you mean by throttle rails though. Take a pic of the part and post it or send it to my email after you PM me. I have lots of pics and also have a spare rack of carbs so I can take more pics if needed.
Offline mick750F
« Reply #2 on: March 14, 2011, 03:58:28 AM »
   You can download a factory Honda shop manual for your bike here. http://forums.sohc4.net/index.php?topic=17788.0
Glosta, MA
bollingball
« Reply #3 on: March 14, 2011, 06:45:07 AM »
The felt washers go on that shaft  see #18 that is not the part# but they go on that shaft you will have to make them 6ea. several post here on that. I think the choke shaft takes orings.
absnaqvi
« Reply #4 on: March 14, 2011, 11:24:42 AM »
Amazingly i was able to put the carbs back together. Im not a pro but am mechanically adept so i was able to reverse engineer the carbs together. Anyway, while trying to take things apart i manage to break the adjuster bolt screw set 4 in the attached exploded view. Anyone know where i can get one of those? The only other option i can see is to get a bolt with a similar thread, cut it to proper length and press it onto the adjuster head from the original bolt. I'd rather not do that if i can purchase one. Maxspeed140, can you spare yours from your extra set?
Also, my carb pump diaphram didnt come with the rubber thingamajiggie as shown in this photo for a replacement part
http://www.vintagecb750.com/parts/480/20-9040.jpg
Do i need this?
bollingball
« Reply #5 on: March 14, 2011, 11:34:38 AM »
That thiggaamajiggie is a dust boot to keep crap from getting down the shaft decide for youself.
Offline jtb
  • An unlikely
« Reply #6 on: March 15, 2011, 05:49:05 PM »
PM me your address.  Do you need the spring too?
1977 CB750F
1985 V65 Sabre
