Author Topic: Part number question - chain tensioner seal/gasket ?  (Read 1004 times)
Offline greenjeans
  • 1972 CB750K2
« on: March 16, 2011, 12:52:39 PM »
75  CB750K
While bringing my old beast back to life, I took off the cam chain tensioner mechanism to give a good cleaning as it was stuck in place.
In the process, the seal/gasket just crumbled.  It is rubber donut with the impossibly small round spring in it.   Can't find a part number for it.
My local Honda dealer doesn't really care to try to find out so.....
The seal/gasket/donut goes inside part number 4 in the pic.  Part 6 slides through it.   Anybody have any ideas short of buying another tensioner ?
Offline dhall57
Re: Part number question - chain tensioner seal/gasket ?
« Reply #1 on: March 16, 2011, 03:03:49 PM »
Item #7 is part# 14592-300-306 and still available from Honda.
I had my tensioner off a while back and I don't remember seeing any donut seal unless it was part of the tensioner housing #4 part # 14530-300-010 which I think is no longer available from Honda. You will have try some other sources.
« Last Edit: March 16, 2011, 03:15:30 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
bollingball
« Reply #2 on: March 16, 2011, 03:14:19 PM »
Are you talking about something to go around the shaft on part #6 if so mine has nothing there and has no leaks maybe some PO put a oring in.I just have part #7 you can make one easy.
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #3 on: March 16, 2011, 10:19:37 PM »
Greenjeans. I hace just had a look at my spare one and can confirm that there is a seal in there. As you say it is not just an o ring but a full seal with the small spring to provide tension. I cannot remember what I did when I put my motor together a couple of years ago but I may have just used an O ring. If you look carefully the front section of the body may just be pressed in. If that can be removed you may be able to measure up for a seal from a local seal supplier. It is possible that this tensioner is used on other Honda bikes. If that is the case then the seal may be identified in their parts breakdown. I will try a little bit harder tonight when I have a bit more time. Pat
Regards
Pat from Australia
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: March 17, 2011, 11:41:25 AM »
Good idea on the other bikes...  I dig around a bit more and see what I can find.
If worse comes to worse, there are several on feebay right now....hopefully under 20 bucks.
Offline CB750F2
« Reply #5 on: March 17, 2011, 02:44:16 PM »
I have had a look at the spare parts breakdowns of other Honda models but no luck with finding a part number for you and I still cannot remember what I did with mine. I will get back to you if I suddenly remember.
Regards
Pat from Australia
Offline CB750F2
« Reply #6 on: March 18, 2011, 04:27:34 AM »
You could possibly tap a thread into the outer end and screw in a plug. Remove it when you need to adjust cam chain tension. Try this on a spare one first to see how it turns out. Pat
Regards
Pat from Australia
