Author Topic: Ooops - broke my Cam Chain Adjuster bolt, CB400F  (Read 7272 times)
Offline dagersh
    • Photos
« on: March 17, 2011, 02:13:02 PM »
Arrrrg!
So, I was tuning up my CB400F, valves, oil change, timing and carb sync.  Got everything done great, and decided to go after making sure my Cam Chain was adjusted.  Well, I got a little too gorilla fisted and broke off the Adjuster bolt located at the lower front of the engine.
I am searching ebay, but no luck so far.  I think its the same as the 350, 500 and 550's.  Anyone have a spare they want to sell?
If not, can I replace it with a 6mm threaded bolt and use 2 nuts as a lock?
Thanks!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Deltarider
Re: Ooops - broke my Cam Chain Adjuster bolt, CB400F
« Reply #2 on: March 17, 2011, 02:33:27 PM »
Don't blame yourself. Many before you share your experience. Poor design by Honda.
CB500K2-ED Excel black
Offline vames
« Reply #3 on: March 17, 2011, 02:40:28 PM »
I haven't had to adjust mine yet, but it looks scary down there so I ordered a new one just in case. Lots of PB Blaster and patience, I suppose, when the time comes.
Offline DarcyCB400F
« Reply #4 on: March 17, 2011, 08:35:41 PM »
Funny (not really) I did much the same as you today...valve clearnace, timing, dwell... cam chain adjustment only to discover PO stripped it!! :'(
Not sure, but I think I will change the bolt first but suspect the case is stripped!
Let me know if you find some for less than $25 on StealBay!
1977 CJ360T
1977 CB400F
1980 CB900 Custom
1981 GS550L
1989 DR200R
1998 VT1100C2 ACE
1999 XR400R
2006 CR230F
2007 HD Road King
« Reply #5 on: March 17, 2011, 11:01:11 PM »
Those bolts ahve been obsoleted for some time but you can use an straight 6mm setscrew with a 6mm nut and plain washer to the case, it may weep a small amount of oil but never seen one leak bad
Offline -CB-Jamie-
« Reply #6 on: March 18, 2011, 01:32:21 AM »
The PO of my bike must have stripped the threads in the crankcase too on my bike, but he came up with a handy enough solution to it. He had a big SS nut with a 6mm thread welded onto to the crankcase and then threaded a 6mm SS bolt through this with a locking nut on it with a washer. Whoever done the welding on this thing was really tidy as well. Now there should never be a problem with stripping threads again hopefully. Also when I got this bike it had been sitting for at least five years and the bolt loosened with minimal effort. It's tidy enough looking as well.
look closely in this pic and you can see it.
« Last Edit: March 18, 2011, 01:34:04 AM by -CB-Jamie- »
72 CB350/4
76 CB400/4 CB400f "Project Resurrection"
77 CB550/4 1977 CB550 Yet Another Cafe
77 cb200
09 cbf600
Offline dagersh
    • Photos
« Reply #7 on: March 21, 2011, 08:08:39 AM »
Thanks Guys!
I will probably just order a new one.  I did not study the diagram carefully, and thought that was where you were supposed to insert a screwdriver if the CAM chain did not react.  So when I tightened it back up, I thought I was activating the the "pusher".
Lesson learned - all the bolt and locknut do is keep the plunger set, the 10mm cap bolt, located about 4 inches above, is where you can manually push the tensioner.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline vames
« Reply #8 on: March 21, 2011, 08:29:59 AM »
Would love to see a better scan of that article.
Offline HondanutRider
« Reply #9 on: March 21, 2011, 08:51:02 AM »
If it's the bolt with the locking nut that you broke, and you can remove the remains from your engine with the threads still intact on the case, then I don't see why a 6mm bolt of the approximate length as original wouldn't work as a substitution.  All it's doing is pressing into the plunger shaft to lock it in place.
That plug above this bolt, can also be replaced with a longer bolt with a locking washer on it.  Rather than sticking a screwdriver down that hole to apply more pressure to the adjuster, a more accurate adjustment can carefully be made (with the engine running), by screwing that replacement bolt in or out more as its end presses on the end of the adjuster linkage.  As I'm sure the articles explain about using a screwdriver in the hole to augment the springs weak adjustment, you don't want to be too heavy-handed in applying too much pressure/tension to the cam chain.  Just a bit more to reduce the slap and rattle as the chain runs 'round.  Then you can lock it in place with a nut, as well as tighten (carefully) the bolt you snapped, also locking it in place with its nut.
Offline dagersh
    • Photos
« Reply #10 on: March 22, 2011, 12:19:49 PM »
That is a great idea!  Will give it a try and post the results.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #11 on: March 22, 2011, 12:38:15 PM »
Vames,
Its on the SOHC4.net site under 400F Tech articles.
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline vames
« Reply #12 on: March 22, 2011, 02:09:36 PM »
Thanks!
