Author Topic: FFJMOORE CB550 BIG bore engine build.  (Read 83389 times)
Offline Flying J
Re: CB550 engine rebuild
« Reply #150 on: October 16, 2011, 09:46:36 PM »
Just did some soda blasting. The air was really wet so it kept getting cloged. So i drained my compressor and i had a decent amount of water in it. But now the drain valve wont seal so i have to go get a new valve before i can use it again.  :(
Cases are taking turns in the mineral spirits bath.
5286
Should i soak all the gears and whatnot or leave them alone?
Offline Syscrush
  • Sold. :(
« Reply #151 on: October 17, 2011, 05:31:53 AM »
On the bright side, you'll have a nice new drain valve. :)
Think about getting an inline air dryer while you're getting stuff for your compressor.
Looking awesome.
Old gears can get porous on the microscopic scale, which results in lubricating oil seeping into the gears and helping them to self-lubricate.
KIDDING! :)
Go ahead and wash 'em up real nice.  It will help with inspection, and ensure that no grit or dirt gets included when you reassemble.
« Reply #152 on: October 17, 2011, 05:43:17 AM »
Instead of bathing in a big volume of solution I use a smaller amount and a soft brush, changing it often so it's always clean, especially for all internal parts.  When you're done oil all the steel goodies including bearings.
Offline Flying J
« Reply #153 on: October 19, 2011, 05:51:34 PM »
ok, cleaned all the gears and stuff. Sprayed them with some WD40 to keep the rust off till i get it back together.
There are a few pieces i found today that im not sure where they came from so im going to do a little searching. I think they might have come from the oil pump.
Picked up a plastigauge from the local machine shop. They just gave it to me for free. I checked 2 rod ends and they were fine so im not going to mess with the others until i get the new nuts and bolts for them along with the rest of the $223 order i placed at honda today. ordered new crank shaf bearings, half dozen seals, and nuts for the cylinder studs.
.003 is the limit.
Offline Flying J
« Reply #154 on: November 01, 2011, 07:10:09 PM »
Well i picked up my parts from honda that i ordered. Found out a few things, 1 when you order a bearing its only half ::), 2 honda doesnt have any "A" crank bearings, 3 honda doesnt have oil seal 91207-374-000 so can i re-use mine?
Do i really need to replace my bearings? If i plastigague them and they are fine will it be OK?
Offline Flying J
« Reply #155 on: December 15, 2011, 11:37:04 AM »
Well, I quit my Sushi job. I was not having fun and I had no time to work on bikes. Plastigauge the crank today and all is well so i guess i wont be replacing the bearings. .003 is the limit.
Offline Flying J
« Reply #156 on: December 19, 2011, 12:05:22 AM »
started primer today but i had to leave before i could apply paint so according the back of the can i have to wait 7 days for the paint to cure.
« Reply #157 on: December 29, 2011, 02:16:47 AM »
if the shells plastiguaged ok just run them,itll be ok,i thought that seal was discontinued?polish the case where the shells sit and the backs of the shells,they all must go back into the same spots,when you insert them square them down with a steel rule,find a flat plate glass and with some worn 320 wet and dry used wet, just take a few strokes on the big end cap and rods,youll see the minute high spots come off,and also polish the seating area.heres one i prepared earlier.
     make these seating areas clean with any polish on a rag.
« Last Edit: December 29, 2011, 02:27:11 AM by dave500 »
Offline Flying J
« Reply #158 on: December 29, 2011, 02:19:40 AM »
Yes it was discontinued. So I'll be reusing mine right?
« Reply #159 on: December 29, 2011, 02:30:56 AM »
your seal looks good,they always reuse ok if someone hasnt pryed it out badly or something,steel wool all the seal seating areas in the case,i like to fit all the seals after the cases are together with a slight smear of compund on them,they close up square easier that way.
Offline Flying J
« Reply #160 on: March 11, 2012, 04:02:40 PM »
Havent forgot about this post, if you dont follow my other build here is the motor update. Clutch cover is welded up and so is the kicker hole in the case.
Things i need to do/think about now are shortening my cam chain to the right length. Also need to figure out what size base and type of head gasket i need to get. Not really sure how to decide.  :-\
Offline Tintop
« Reply #161 on: March 11, 2012, 05:31:30 PM »
Still following along. ;) :)  Glad to see/hear things are progressing.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #162 on: March 12, 2012, 12:00:55 AM »
was the cover damaged?you might have been able to knock a brass freeze plug into the kicker hole?that way its reversible.
Offline Flying J
« Reply #163 on: March 12, 2012, 03:38:39 PM »
No it wasnt damaged but a freeze plug would look funny on a polished aluminum cover.
I shortened my TSUBAKI cam chain. I pressed on the Link but im not sure if i need to smash the ends like the other ones. I would hate for the chain to come loose. Any advice?
Google search sorted me out. Used my chain riveter. I have never riveted a chain so that was new.
« Last Edit: March 12, 2012, 04:01:13 PM by ffJMoore »
Offline fastbroshi
  • Puppet
« Reply #164 on: March 12, 2012, 06:20:47 PM »
If it's anything like drive chains, there might be a spec for how large the stakes' diameters should be once they're in place.
Just call me Timmaaaaay!!!
Offline Flying J
« Reply #165 on: March 12, 2012, 07:24:43 PM »
Here is my riveting job. Dont think it will back out and it moves freely.
Well I was going to start putting the crank and conecting rods together with the new bolts that bwaller sugested but when i went looking for them I could not find them or the seals. I just saw them a few days ago so I looked everywhere for the next hour or so untill i found them. I had moved them to a safe place near the work bench where i wouldn't forget about them.  ::) Any way once i found them i realized i only had 6 sets, I need 8. So Ill order some tomorrow. Here is the differance in the 550 to 750 bolts.
« Last Edit: March 12, 2012, 07:26:44 PM by ffJMoore »
Offline fastbroshi
  • Puppet
« Reply #166 on: March 12, 2012, 07:57:57 PM »
th=338 height=600]http://i58.photobucket.com/albums/g276/thepanman99/CB550%20rebuild/IMAG0282.jpg[/img]
  I'm certainly not an expert in chain riveting, but that one on the left looks as if the outer edge started to thin out and crack.  Kinda like if you had a sphere of Play-doe and smashed it from the top.  Once you flatten it out so much the outer edge would start to crack.   Might be worth the extra time to redo it, peace of mind and all that.
Offline Flying J
« Reply #167 on: March 12, 2012, 08:36:45 PM »
Yeah, I'm not happy with how that looks. Think I'll order another one from z1
Offline Flying J
« Reply #168 on: March 19, 2012, 06:39:39 PM »
Ok, i fixed the camchain.
I put the new bolts and nuts on the con rods. The bolt has a raised side that was the side i put against the con rod. Is that correct?
Got the bottom half back together.
Offline Flying J
« Reply #169 on: March 19, 2012, 06:45:32 PM »
F ME! I didnt put the cam chain on!!! >:( >:( >:( >:( :'(
Offline Tintop
« Reply #170 on: March 20, 2012, 05:06:25 AM »
Any other bits left over, besides the cam chain? ;) :)
77 CB550 Cafe build
Offline tweakin
  • tear down
« Reply #171 on: March 20, 2012, 07:20:11 AM »
That blows.  I have left out an oil seal before when I sealed up the cases, not fun.
« Reply #172 on: March 20, 2012, 09:29:42 AM »
No problem if you are using a cam chain with a master link.
Offline Flying J
« Reply #173 on: March 20, 2012, 09:36:35 AM »
I had already riveted the chain. No problem though. I got the chain on and then did a dry run of putting on the top half. Took a little fiddling and figuring out what was going wrong but it went on. So I'll Honda bond them together today. Then i have to put the shift mechanism back together. That part looks confusing and i remember it being difficult to take apart. Slow and steady. Thanks for the help guys.
Offline Flying J
« Reply #174 on: March 25, 2012, 08:28:38 PM »
Doing a dry run is a big help. It gets all the dowels and forks aligned so when you have hondabond everywhere the cases slide right together. Torqued all the main bolts so now i just have to put the rest of the case bolts in, then i will install the studs.
Anybody want to walk me through how to figure out what thickness base gasket and head gasket I need?
