Author Topic: caliper bleed nipple, what size thread ?  (Read 11183 times)
Offline Helmet Hair
« on: March 19, 2011, 01:34:39 AM »
during a rebuild of my brake calipers one of the bleed nipples sheared off as it was siezed into the caliper body, that has now been removed by an engineering firm but the new bleed nipple, advertised as being suitable for my bike wont lead into the port.
the replacement nipple seems to be 8mm dia with 1.25 pitch but the threads in the caliper body look more like 1mm pitch.
Do any of you have some tech spec on what the correct size the thread should be so I can get a tap and clean up the lead threads into the port ?
The bike is a '82 CB650SC Nighthawk with twin piston calipers
Offline Motoguy23
Re: caliper bleed nipple, what size thread ?
« Reply #1 on: March 19, 2011, 11:07:23 AM »
Well I know that a CB500's bleed nipple is 1.0 X M7.  Not sure if that will help you but honda does like to keep using the same parts as long as they work.  My XR200 was basically unchanged from 1990-2002.
All glory to the hypno-toad.
Offline cobrajunkie
« Reply #2 on: March 19, 2011, 01:32:53 PM »
I found a part number for ya but not size. Part number is;  45224-413-003
Same size fits these...
CB400T HAWK US
CB400A HAWK HONDAMATIC US
CB750K 750 FOUR K '79 US
CB650 '79 US
CM400C CUSTOM 1979 US
CB650C '80 US
CM450A HONDAMATIC 1982 US
CB450SC NIGHTHAWK 450 '82 US
CB450T HAWK US
VT750C SHADOW 750 1983 US
VT700C SHADOW 1984 US
CB750C 750 CUSTOM '80 US
CB650SC '82 NIGHTHAWK 650 US
CB400TII '78 US
CB400TII '79 US
CB750L LIMITED 1979 US
CB750K 750 FOUR K '80 US
CB750K 750 FOUR K '81 US
CB750K 750 FOUR K '82 US
CM400A HONDAMATIC 1980 US
CM400A HONDAMATIC 1981 US
CM400T '79 US
CM400T '80 US
CM400T '81 US
CB650C '81 US
CB650 '80 US
CB650 '81 US
CB650 '82 US
CM450A HONDAMATIC 1983 US
CM450C '82 CUSTOM US
CB450SC NIGHTHAWK 450 '83 US
CB450SC NIGHTHAWK 450 '85 US
VT700C SHADOW 1985 US
CB750C 750 CUSTOM '81 US
CB750C 750 CUSTOM '82 US
CB650PZ
CB750KZ 1979 FOUR (CANADA)
CB750LZ 1979 FOUR (CANADA)
CB750KA 1980 FOUR (CANADA)
CB750KA 1980 FOUR (IRELAND POLICE)
CB750KB 1981 FOUR (CANADA)
CB750KZ 1979 FOUR (GENERAL EXPORT KPH)
CB750KZ 1979 FOUR (GENERAL EXPORT MPH)
CB750KZ 1979 FOUR (ENGLAND)
CB750KZ 1979 FOUR (EUROPEAN DIRECT SALES)
CB750KZ 1979 FOUR (FRANCE)
CB750KZ 1979 FOUR (GERMANY)
CB750KZ 1979 FOUR (SOUTH AFRICA)
CB750KZ 1979 FOUR (AUSTRALIA)
CB750KA 1980 FOUR (GENERAL EXPORT KPH)
bollingball
Offline Helmet Hair
« Reply #4 on: March 20, 2011, 03:26:01 AM »
Thanks guy's, Ive got the right part number that I quoted to the supplier, whether Ive got the right part is another matter.
I've measured the diameter from the remains of the sheared nipple and its 8mil, give or take a decimal point or so, the problem is the thread pitch, I dont have a set of pitch gauges to check this aspect. If someone has a spare or used nipple that they can measure up and establish exactly what the dimensions are I might simply need to chase out the existing threads, if Ive been sent the wrong part I'll tear them a new one   >:(
Hope someone can help on this
bollingball
« Reply #5 on: March 20, 2011, 04:18:05 AM »
Sorry I do not have one to measure. If you do have to return it consider a speed bleeder. I was not so sure about them at first now they are on all my trucks & cars and of course the 750 ;)
bollingball
« Reply #6 on: March 20, 2011, 04:28:02 AM »
Offline cobrajunkie
« Reply #7 on: March 20, 2011, 04:40:45 AM »
http://forums.sohc4.net/index.php?topic=14157.msg139037#msg139037
Have you looked here?
That thread doesn't show size or speedbleeder part number for his ride.  If you can find the speedbleeder part number, you can then easily find the size.  I think that list has an error.  The CB400T '80 - '81 Hawk is listed with two different part numbers.  I don't think that bike should be associated to part# 43352-568-003.  Otherwise, the mystery would be solved.
OEM Part# 5109-300-003           ====> Speedbleeder SB10125 = M10x1.25
OEM Part# 45224-579-013          ====> Speedbleeder SB7100 = M7x1.0
OEM Part# 43352-568-003          ====> Speedbleeder SB8125 = M8x1.25
OEM Part# 45224-413-003          ???
Offline Helmet Hair
« Reply #8 on: March 20, 2011, 08:44:39 AM »
Thanks for your input so far guys.
The part number for it on the CMSNL.com site is 45224413003, visually it's identical to the remains of the one that came out of the caliper, unfortunately it dont look anything like what I've been sent as a replacement
http://images.cmsnl.com/img/products/valve-bleeder_big45224413003-01_3bdf.jpg
this is what came out (in bits  :-\ )
its the part number that Bowlingball has a question mark next to in his last post
« Last Edit: March 20, 2011, 08:46:35 AM by Helmet Hair »
Offline Helmet Hair
« Reply #9 on: March 21, 2011, 10:29:14 AM »
Ok, I need to pay more attention to the scale on my vernier caliper, the bleed nipple thread is 7 mm diameter not 8 so Im slightly embarrassed by that *&^$ up, however those Idiots still sent the wrong part coz I quoted them the part number.
3rd time lucky with the order maybe ?
Offline johnrdupree
« Reply #10 on: March 21, 2011, 12:24:24 PM »
You should be able to pick one up at the local auto parts store.  I needed two for a dual disc conversion and got the pair at NAPA for about $5 instead of $10 each from Honda.  I'm not sure what the UK equivalent to NAPA is, but there has to be one.  If you can take your remnants down to the store you can compare threads and look at what you're getting.  Hell, take the whole caliper if you can.
Good luck,
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline Helmet Hair
« Reply #11 on: March 22, 2011, 12:49:58 PM »
Thanks John, whats NAPA ? sounds like some place where wine comes from  ;)
Finally ordered a pair from a Honda main dealer using the OE part number, hope to get it all sorted this weekend, thanks for your collective input guys
Offline fastbroshi
  • Puppet
« Reply #12 on: March 22, 2011, 01:24:48 PM »
It's an M7 X 1.0.  The Speedbleeder pn is SB7100; add an S to the end if you want stainless.
Just call me Timmaaaaay!!!
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #13 on: March 22, 2011, 01:30:32 PM »
Also, for minimal money (like $15) you can send your caliper to Speed Bleeder in IL and they will repair it for you. Shipping & labor are free. Just had mine replaced by them.
Offline fastbroshi
  • Puppet
« Reply #14 on: March 22, 2011, 01:34:13 PM »
Got a little ahead of myself, you guys alread answered it.
« Last Edit: March 22, 2011, 01:35:55 PM by fastbroshi »
Offline johnrdupree
« Reply #15 on: March 23, 2011, 06:18:25 AM »
NAPA is a parts store that caters more to professional and advanced shade-tree mechanics than the boy racer types.  It's the kind of place you can get obscure tools or a piston for a '49 Chevy but not steering wheel covers and underbody light kits.  When I went to get bleed valves I had one with me.  I walked in and they asked me what I needed.  I held up the valve and told them "a metric bleed valve, 7 x 1.0, about this long."  One guy starts looking through his five foot long row of catalogs, the other guy walks about two feet into the rows of shelving and comes out with a metal box.  He opens the lid, scans the labels on the inside, and pulls out a duplicate of what I'm holding.  I tell him "perfect, I'll take two."  Catalog guy turns around and has a "yeah, well, there you go" look on his face.
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: March 23, 2011, 06:24:15 AM »
We always buy two, don't we.  ;) :)
Offline johnrdupree
« Reply #17 on: March 23, 2011, 10:38:46 AM »
I'm setting up dual discs so I actually needed two.  Maybe I should have bought a spare...  :-\
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
Offline Helmet Hair
« Reply #18 on: March 23, 2011, 04:41:34 PM »
Hi John, I cant think of anywhere around my area like NAPA. there is a distinct lack of places to get specialized tooling or slightly obscure parts over here these days. even the breakers yards are so over regulated here it can be hard to come by decent seconds at a decent price, I can remember crawling about the breakers with a pocket full of tools taking off the bits myself and going to the old boy in a shed who had a petty cash box.
Offline fastbroshi
  • Puppet
« Reply #19 on: March 23, 2011, 04:52:50 PM »
What, can you not do that anymore?  I remember doing the same thing looking for parts for my buddy's '86 Hyundai Excel....BARF!!
Offline backwoodsman
« Reply #20 on: March 23, 2011, 04:54:39 PM »
Had the same problem bought the new speed bleeders cause I like the easy bleeding they just didint seem to fit right you know when you screw them in by feel just didnt feel right must be the taper. Put my old rusty ones back in.
Offline fastbroshi
  • Puppet
« Reply #21 on: March 23, 2011, 08:19:25 PM »
The speedbleeders come with a sealing compound preapplied to the threads, may have been what you were feeling.
