Author Topic: Whats the best way to Clean a gas tank?  (Read 6031 times)
Offline the architect
Re: Whats the best way to Clean a gas tank?
« Reply #25 on: March 23, 2011, 03:44:14 PM »
For light surface rust, I absolutely love using The Works toilet bowl cleaner.  I usually swish it around with some stainless, sharp, pointy drywall-type screws.  Rinse a few times, neutralize any remaining cleaner (acid) with baking soda + water (or laundry soap or any other solution with a base pH) and then fog the tank with fogging oil or WD-40 (or fill it with gas).
I recently used an electrolysis setup for cleaning a really bad tank.  I wire wheel cleaned the electrode every night (in my case, a piece of rebar from Home Depot).  With my wimpy battery charger, it took 3 weeks (6 amps at 12 volts), but again, this was a seriously fuel-varnished tank.  I switched out my solution once a week (it looked like coffee each time).  Then I followed up with a rinse of The Works (no screws, this time) using the process above, and it looks sparkly a new inside.
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
Offline Bankerdanny
  • Endeavor to persevere
« Reply #26 on: March 23, 2011, 04:31:26 PM »
Bankerdanny You photo looks pretty good. What concentration of The Works? Did you mix it with water in the tank or outside the tank. How long did you leave it? Was there a lot of gas produced?
I did two treatments because the scale and varnish in my tank was heavy after 30 years of sitting 2/3 full of gas. I used it straight for the first round, then mixed the second bottle with a gallon or so of water.
It does produce fumes (visible fumes actually). I emptied the bottle inside, added 2 one foot lengths of a medium size chain, put the cap on, shook it around for a minute or so, then let it sit for about 10 minutes before emtying the liquid and flushing with water.
The second treatment I cut the cleaner with about 1 a gallon of water. But if the rust in light in your tank, you could most likely use the dilluted solution vs the straight cleaner. But I don't think it makes a difference which way you go.
After the second treatment I rinsed the tank with half a box of baking soda and a couple gallons of water.
Offline cookindaddy
  • I sure love this bike!
« Reply #27 on: March 23, 2011, 05:55:52 PM »
Thanks Bankerdanny
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
